tired of tranys going out! 1982 Blazer, t-350 trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2010, 04:05 PM
i have a k5 thats going threw transmissions
I have a 82' K5 blazer w/ built 400small block and short shaft 350 turbo. I keep cracking the bell housing. and burning belts in the trany, we have gone through 3 tranys in 5 months.........what can be causing this and how do i prevent it??????????? tired of boxing with this.
Old 11-23-2010, 04:11 PM
Old 11-23-2010, 04:32 PM
Motor mounts in decent condition?
Frame-to-body mounts in good condition?
SOMETHING is causing too much stress on the bellhousing; and I'm guessing it has to do with frame flex. Unsupported weight (the transfer case, for example) could be an issue too.
Belts??? Do you mean "Bands"?
1. Is the transmission built right to begin with? I don't do TH 350s, but the band adjustment on a 400 involves select-length engagement pins. Wrong pin = wrong band adjustment. I bet the 350 has a similar adjustment.
2. Trans pressures correct?
3. Trans fluid cool enough? Do you know what the fluid temp is?
4. Do you operate the trans in "Drive" or do you manually shift? How do you drive the vehicle?
Old 11-23-2010, 04:51 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Ok here's the deal from my experience anyway, Are the motor mounts in good shape and trans mount ? You have some serious flex somewhere which is probably a bad mount somewhere check the trans mount and motor mounts also, Your getting too much stress on the bell-housing, and I'm willing to bet it has to do with frame flex/ engine and trans flex. Or both JMO
Where at on the bell-housing did it crack at exactly? I had one go from one side to the other had like a couple inches holding it at the starter side of the bell. Does it still have the 4x4 equipment in it ?
Cole
Old 11-23-2010, 05:04 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
Also check the mating surface between engine and trans is smooth and flat (I scrape the paint off too). And the 2 dowel pins need to be there.
Old 11-23-2010, 05:34 PM
DoubleVision's Avatar
Even so your not going to believe me if I tell you this. Check the dowel pins in the block. If they are not present, or pushed in too far, the result is cracked bellhousings. If they are out far enough and all looks okay then it`s binded, likely due to frame damage sometime in the vehicles life. I only seen 1 vehicle in my time that ate transmissions and it kept doing what yours is doing. It was a 79 camaro, the car looked absolutely mint but it had been wrecked and very well repaired, but not correctly which kept the transmission in a bind.
Old 11-23-2010, 05:40 PM
eloc431962's Avatar
Wiki Edits: 37
Hummmm!!!!!!!!!!! There are to post on the same thing from the same person.
Anyway your right DV i have seen this also with the dowel pins. and the wreck yep that's a given also if twisted bad enough it can do some strange things.JMO
Cole
Old 11-23-2010, 05:43 PM
grrrr tranys!
the fiest one cracked at the rear casing, The 2nd 350turbo cracked around the bell housing all the way around. Then the third one is slipping, I lost drive gear and had to shift manualy from
1st into 2nd then drive, then 1st&2nd went out and reverse, It was acking like the trany fluid was low, but I checked that and changed out the fliter and its not the fluid or filter..............
Old 11-23-2010, 05:48 PM
eloc431962's Avatar
Wiki Edits: 37
You really need to check all the mounts engine and trans and see if there is one bad causing to much flex. And make sure the dowel pins are i place and doing their job as well. The cracking is from to much flex or some frame twist or maybe some damage from a wreck i don't know the history of it how long have you had it? You never said is it still 4x4 and what do you do with it play or DD and play ?
Cole
Old 11-23-2010, 05:52 PM
mud.man.rj's Avatar
trans cracking
Make sure your spacers on the transfer case crossmember are between the frame and mount not under the mount or above the frame. They are on one side of the mount to frame only, I think passenger side.
Old 11-23-2010, 05:56 PM
yes all 4x4 is in.......
yes the 4x4 is in the truck
Old 11-23-2010, 05:58 PM
eloc431962's Avatar
Wiki Edits: 37
Check your other post people have post on it also.
I would be checking all the mounts.JMO
Cole
Old 11-23-2010, 07:01 PM
trany........
I realy apprieciate all the help guys, I need it......... the truck has a 6' lift and there r spacers 4 the lift , all the mounts r good, it has to be the flex but where is it coming from.....PS im new to this wonderfull site so bare with me
Old 11-23-2010, 09:12 PM
DENCOUCH's Avatar
Dude! 6' of lift?
Old 11-24-2010, 01:11 PM
bigdog7373's Avatar
Of course it's fast
Aha. So you got a big truck with a big engine, big lift and big tires and the tranny hasn't been upgraded to handle the extra stress. I also agree on the dowel pins too.
Centrifugal advance DENCOUCH Engine 7 05-07-2010 06:39 PM
trans from 1500 to s10 blazer thebreeze68 Transmission - Rearend 1 01-02-2010 03:59 PM
Turbo 350 Trans Shift/Slip issues CincyMuscle Transmission - Rearend 5 09-30-2009 07:17 PM
We pulled our 350 and trans for our beetle project - pics zbhover Engine 3 10-06-2008 03:40 AM
White Smoke, I'm at a loss 58Chev Engine 31 09-25-2006 04:29 PM
