Tired of what i have want something different - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2006, 06:39 PM
Last journal entry: frame build
The four wheel discs are nice and the build was fun. Now it is time for something different. An extra set of Pontiac 8 lugs set me thinking- I never seen them on a rod before. So, the game is afoot. The rears appear to be almost a bolt on on the 54 olds rear axle. The front is a different story. The spindles are, I think, aftermarket 37 ford spindles. The length is fine and the outer bearing is a perfect fit. The inner and seal is a different story. The diameter for the inner is an eighth to small and the seal is a quarter to small.
My bearing books don't list a bearing that has the right inner and outer diameter in the right thickness. So, I was wondering, has anyone tried putting a sleeve on the spindle to correct a fit. I was thinking about a .003 sweat fit would keep the sleeve there forever especially if a little bearing mount was used.
Any ideas or comments?
Old 10-15-2006, 06:46 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
I don't know if this relates or not, but it sounds similar.
The front disk "kits" for the straight axle ford trucks (Mid 50s) use a sleeve for the rear bearing and then the disks from a late model truck. They usually heat the sleeve to get it to go on and once its cooled....thats it....no getting it off again.
I have no clue what seal they use, since my 56 is stock drums brakes all the way around.
Old 10-15-2006, 06:56 PM
Thats what I am talking about. Just wanted some feedback from others that have done it before I go off the deep end
Old 10-15-2006, 07:02 PM
Brian_B's Avatar
Lost in the 50s!
I have never done it. There are a lot of the ford trucks running around with the kits though. Go over to ford truck enthusiasts and look in the 48-60 area.
Or look at CPP for a parts picture:
CPP
You can see the shims in that pic.
Old 10-15-2006, 07:07 PM
Looks to me like this project is a go. Thanks for the link.
Old 10-15-2006, 08:22 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
You mention "bearing books" in your post, but I might suggest that you try an on-line search at SKF Bearings
There is a LOT of information there, although navigating it is a little tough. Look for "Product tables" on the RH side of the page, just under the "Taper Roller Bearings" text header (or immediately above the "Taper Roller Bearings" link.
When you do get to the product table, you'll notice that all of the specs are metric ... and that they use a "," (comma) instead of a "." (point). Click on the [IMP] button to change the displayed info to Imperial (inch) specifications.
Actually, here's a direct link to
Page 1 with the inch measurements in place. I'm going to bookmark it right now!
Tired of the white stuff!!! xtreme off-road Off-Topic 24 11-23-2010 11:16 PM
3500 miles in 10 days - man I'm tired Centerline Hotrodders' Lounge 17 02-08-2005 08:20 PM
jeezuss, god i'm tired. almost anti-climactic bullheimer Hotrodders' Lounge 7 12-30-2004 03:15 PM
What model hot rod are you tired of seeing? MoparReligion Hotrodders' Lounge 56 08-31-2004 08:51 PM
Freakin A...... I am tired of making parts "fit" TurboS10 Hotrodders' Lounge 14 06-18-2003 06:14 PM
