-   -   Tires (http://www.hotrodders.com/forum/tires-198063.html)
gbowne1 05-07-2011 07:45 PM
Tires
I am going to be using 14" wheel rims and have some idea of what tires will work but they are going to be 185 or 195.. 60 to 80 R14's. Have not decided what might work It's on a 14x6" wheel rim.
The other tires will be on 15x7's.. haven't worked out what will work there either.
Any suggestions here?
eloc431962 05-07-2011 11:06 PM
It will depend on what they are going to be on . IMHO
Cole
gbowne1 05-08-2011 12:01 AM
I just recently noticed that the chassis I used is roughly the same dimensions of the Pontiac Fiero which has become populuar with KitCar builders.. while it is in no way a Fiero. To measure, I used an engineering tape for the dimensions. Hadn't been too concerned about the offset since the 14x6's were there originally.
It's about 13ft long.. 160.7" I calculated.. about 2,464lb base weight, 2,735lb (took it to a tonnage scale to weigh it) as fully loaded, uses mounting for a 5spd Manual gearbox on a 4cyl or 6cyl.
Wheelbase is a 93.4" (7 and 3/4') .. Height=46.9" (about 4') and Width: 68.9" (almost 5-3/4')
The engine only does 92-140hp @ 4,000rpm. LoL. Gotta do somethin about that.
matts37chev 05-08-2011 09:22 AM
what kind of car are you building?
eloc431962 05-08-2011 09:25 AM
X2 got any pics of your project ?
Cole
gbowne1 05-08-2011 06:44 PM
No pics yet. Will have some in a little while. I noticed when the 10-12 gal tank is completely full its way heavier. I had to replace the fuel pump and the relay and rewire it.
My car looks a lot like this one.. http://www.youtube.com/watch?v=m_aVLRuOg_o by vette139.
Though mine is a front engine.. not a rear engined vehicle like this one is..
I used a lot of OEM parts. It has a custom designed hand fabricated body.
It's not what I would call a "Kit" car.
I started to build it because the vette139 videos on youtube inspired me.
I bought some Cragar SST 14x6 on 5 lug on a 4" pattern. I believe that they are 3-1/4" backspace... not sure. I orignally looked for their Series 61's which I think are 3-3/8" backspace.
It's sitting on spring fronts with KYB's GR-2. The front's are Moog springs.. the rears are Eaton. Seems to be pretty good.
gbowne1 05-11-2011 12:34 AM
Thanks, yeah I need to post pics. Don't have many. Will post some more soon.
I am working on the brakes (Wilwood), Suspension, Tires & wheels right now.
I don't think it's as nice as the Vette139 car but it sure looks nice painted Boyd Red.. wanted a blue but.. this was a beautiful Red I've seen.
gbowne1 05-21-2011 07:05 PM
I don't see the reply here mark10..
not much to report..
just got my new gages hooked up.
Autometer UltraLite.
I might have to change the front springs but we will see.
Mine looks a little better than the tikicar too thats on youtube.. but not much better than the Ariel atom even Vette's car.
If I gave it a class.. it would be sport touring.
el pollo 05-23-2011 04:27 PM
If staying with a 14x6, I'd suggest 185/60R14 for the size. At that light of a vehicle, and with the narrow rims, I wouldn't go much wider because the tread would round out a bit and wear the centers. It will also handle like a shopping cart.
gbowne1 09-16-2012 02:31 PM
What about the 15x7's? what will work there?
gbowne1 08-25-2014 12:50 AM
Found some American Racing 15"x7" with 5x4.5" (5x114.3mm) in several different offsets. 15x8 will also fit too on the rear. But might actuall use 15x7 all the way around. Sold the Cragars. I would like to see if 0 offset would work. But seems like my rim is offered in -6, 0 and 6.
BuzzLOL 08-25-2014 01:35 AM
. You need to support the vehicle by the front spindles and rear axles ends and see what size compressed tires give the ground clearance and stance you want to end up with... (add weight to the chassis to mimic any body and passenger weight you will be adding)...
. I have 185-60R14's on the front of my '87 Firebird GTA and 275-50R15's on the rear... old American Racing Torque-Thrust 'mags' with gold spokes...
. This slick calculator will give tire height from size spec.s... and other info... (hit 'clear right' button before doing anything):
http://www.f-body.org/gears (may have to type URL in manually to get it to work because this site uses some kind of an advertising system to handle our links which sometimes gets them blocked by ad blockers)
gbowne1 08-25-2014 07:14 PM
It's a tubular chassis like the Atom/Locost. I'd considered other options for chassis.
Something like one of these..
https://www.youtube.com/watch?v=m_aV...myljaRICq1C8WA
https://www.youtube.com/watch?v=n_x7...myljaRICq1C8WA
https://www.youtube.com/watch?v=fWmW...myljaRICq1C8WA
gearheadslife 08-25-2014 07:28 PM
14" tire sizes are becoming very limited.. pick a size you know you'll be able to get a replacement if needed..
gbowne1 08-25-2014 07:33 PM
Yes, I've seen that happening around here in the Pacific NW.
