It will depend on what they are going to be on . IMHO
Cole |
I just recently noticed that the chassis I used is roughly the same dimensions of the Pontiac Fiero which has become populuar with KitCar builders.. while it is in no way a Fiero. To measure, I used an engineering tape for the dimensions. Hadn't been too concerned about the offset since the 14x6's were there originally.
It's about 13ft long.. 160.7" I calculated.. about 2,464lb base weight, 2,735lb (took it to a tonnage scale to weigh it) as fully loaded, uses mounting for a 5spd Manual gearbox on a 4cyl or 6cyl. Wheelbase is a 93.4" (7 and 3/4') .. Height=46.9" (about 4') and Width: 68.9" (almost 5-3/4') The engine only does 92-140hp @ 4,000rpm. LoL. Gotta do somethin about that. |
what kind of car are you building?
Cole |
No pics yet. Will have some in a little while. I noticed when the 10-12 gal tank is completely full its way heavier. I had to replace the fuel pump and the relay and rewire it.
My car looks a lot like this one.. http://www.youtube.com/watch?v=m_aVLRuOg_o by vette139. Though mine is a front engine.. not a rear engined vehicle like this one is.. I used a lot of OEM parts. It has a custom designed hand fabricated body. It's not what I would call a "Kit" car. I started to build it because the vette139 videos on youtube inspired me. I bought some Cragar SST 14x6 on 5 lug on a 4" pattern. I believe that they are 3-1/4" backspace... not sure. I orignally looked for their Series 61's which I think are 3-3/8" backspace. It's sitting on spring fronts with KYB's GR-2. The front's are Moog springs.. the rears are Eaton. Seems to be pretty good. |
Thanks, yeah I need to post pics. Don't have many. Will post some more soon.
I am working on the brakes (Wilwood), Suspension, Tires & wheels right now. I don't think it's as nice as the Vette139 car but it sure looks nice painted Boyd Red.. wanted a blue but.. this was a beautiful Red I've seen. |
I don't see the reply here mark10..
not much to report.. just got my new gages hooked up. Autometer UltraLite. I might have to change the front springs but we will see. Mine looks a little better than the tikicar too thats on youtube.. but not much better than the Ariel atom even Vette's car. If I gave it a class.. it would be sport touring. |
If staying with a 14x6, I'd suggest 185/60R14 for the size. At that light of a vehicle, and with the narrow rims, I wouldn't go much wider because the tread would round out a bit and wear the centers. It will also handle like a shopping cart.
| Tires | Chevy 84 | Hotrodding Basics | 3 | 05-29-2008 05:52 PM |
| What other tires would fit? | Double_v23 | Suspension - Brakes - Steering | 2 | 04-21-2008 11:38 AM |
| BFG tires | scotty47 | Suspension - Brakes - Steering | 9 | 06-17-2004 08:35 PM |
| Tires | Jzarczyn | Suspension - Brakes - Steering | 3 | 02-25-2004 11:42 AM |
| I NEED TIRES ,,,,,,,,,,,,,, | STATUTORY GRAPE | Hotrodders' Lounge | 1 | 01-07-2003 11:24 AM |
