Tires need balanced - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2011, 08:38 AM
Tires need balanced
Since I purchased my 1971 nova I also went to jegs an purchased 15 x 8 cragar ss rims and new ta radial tires. I have since found that I get steering vibration at around 65mph. I would assume that since the car did not do that with the old tires and rims that the new ones are out of balance. I have had 2 places balance them but the problems still exists. I any one can advise it would be greatly appreciated.
Old 05-13-2011, 09:47 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
It could be several things. You could have a faulty tire with a bad/separated belt. If you went with a wider tire, the increased pneumatic trail and wider contact patch could be causing issues - if the tie rod ends or some ball-type joint in the front suspension/steering was worn, it could have not been a problem on the old skinny tires but now it is on new wider tires.
You could also have a wheel that was bent in shipping? Maybe a rotor with inclusions or warping that is grabbing a tiny bit?
Old 05-13-2011, 11:51 AM
malc's Avatar
Living At The Speed Of Life
Those Cragar rims with the slots for the studs, one size fits all, are
aweful to get balanced, mine were never totally right.
Be sure to read the instructions on balancing that came with the rims.
If I remember they are balanced on the wheel center not the stud "slots".
externally balanced vs interally balanced? bwomp969 Engine 7 06-15-2009 03:47 PM
Should I get my engine balanced? maxpower_454 Engine 21 03-20-2009 09:13 PM
balanced assembly BBCMudbogger Engine 7 05-23-2007 03:52 PM
How is the 429 balanced? HOUCKXLR8 Engine 3 04-03-2007 10:03 PM
motor is balanced to 8,000 rpm...help? daddys girl Engine 14 11-25-2005 10:14 AM
