tires for a nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2003, 09:32 PM
nova63and66's Avatar
New Member
tires for a nova
i was wondering what size tires would fit under my 63 nova and what tires would be better to run (radials or the dot street tires)
Old 11-23-2003, 07:31 PM
poncho62's Avatar
Wiki Edits: 5
You wont get a very big tire under a 63 Nova. Maybe a 225X14 max. Get a good set of radials.
Old 11-24-2003, 01:00 AM
You may get a 235 60 15 on a 4 and a half inch negative offset rim; like the Chevy rallies 7 inch rim. To play it safe go with the 225. Each Nova may vary a little in room you have. Check out ' Scotts Nova Resource'
Old 11-24-2003, 05:49 PM
Fastncrazy's Avatar
Can't resist temptation
I have a 63 nova ss, looking for tire sizes also and have been told that it will fit 235/60-15 best, i was hoping that it would fit wider without tubbing the thing, but i think 235 are the best bet with proper clearance-no problems. If you find out anything else let me know, it would be appreciated.
Old 11-24-2003, 05:55 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
Hey guys, the 235/60's are the biggest I've ever seen in one that's not at least mini tubbed. If you want my opinion, at least mini tub it...hence the name "got 2 be tubbed"! I know it takes a lot more fab'n than most want to do, but the look can't be beat! I'm still mad at myself for only fitting the 18.5's in the back of mine.
Old 11-29-2003, 11:44 AM
New Member
thanks for the info i think ill try the 225 60 15 and the radials
