tires one at a time? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2006, 06:30 PM
ok so here is the deal, i have a 91 mustang and i'm putting a 351w in it eventually
but now i have 4 lug patterns with a small 7.5 rear end,
i have the spindles and brakes and hubs from a 97 mustang, they bolt right on to the old struts and now i'll have bigger brakes, sealed hubs and 5 lug patterns on the front
I will obviously have to get new wheels because of the lug change, and i dont have a different rear end yet,
does anyone see a problem with only changing the front 2 tires and wheels (for about a month or two, daily driven) until i get a rear and the correct setup for the back?
i will be having the front aligned and the tires will be a little less wide than stock, will be the same size/height tho
thanks
Brendn
Old 08-24-2006, 06:45 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I see nothing at all wrong with that.
Old 08-24-2006, 09:37 PM
Mr. Murphy would warn you that as soon as you do that you will get a flat tire with the bolt pattern that you don't have on the spare. I would carry 2 spare tires for those few months.
Where can I get these BFG tires? rusttorod Hotrodders' Lounge 6 04-16-2006 01:20 PM
Rear tires on a T-Bucket cucumber1949 Hotrodding Basics 7 08-05-2005 03:32 PM
Tires for 4" wheels dh79 General Rodding Tech 6 07-27-2005 07:37 PM
need help on understanding time slip from drag strip 69elcaminoss General Rodding Tech 12 04-18-2004 12:52 PM
finally time to put my indian back together bullheimer Hotrodders' Lounge 8 03-03-2004 07:23 PM
