Tires and Rims - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2011, 05:38 PM
Tires and Rims
I have a set of 38.5x16x16.5 swampers. They are Bias and I hate them very much. They were on the truck when i bought it. I have a set of 37x12.5x16.5 radial mudder terrains. My issue is that I THINK my rims are 14 inches wide. I hope that the ARE 12 inches but I dont know. My question is can I mount a 12.5 wide tire on a 14 inch wide rim. (if the rim is 14 inches wide)
Old 04-30-2011, 11:24 PM
327NUT's Avatar
I've never used that big of a tire but normally you wouldn't want to install a tire that is wider than the wheel. I think a 12.5" tire would work much better on a 10" wheel.
Old 05-01-2011, 08:09 AM
tire and wheel
The tire is only 12.5 and the rim 14. That is only about 1.5 wider than the actual rim i wouldnt think that is to much of a strectch
Old 05-01-2011, 08:52 AM
327NUT's Avatar
Did you read my reply? you normally don't want to run a wheel that is wider than the tire. Now if you don't think "that is to much of a stretch" then by all means install them and enjoy.
Old 05-01-2011, 09:09 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
do you take this truck out and thrash it in the mud etc.?
or is it just a tall truck you use for every day truck stuff?
ok, never mind, it doesn't matter because you said 16.5
16.5 wheels do not have a bead retention lip like other wheels do
i would not even put a 12.5 tire on a 12 wheel when you are talking about 16.5
you need to stay a couple inches narrower than the tire
i would start looking on craigslist for some 16" wheels and tires, they are pretty cheap if you take your time looking, most guys are going to bigger wheels (17-22) so the 16s are pretty easy to find
tires on rims, any ideas? jeffery wells Hotrodding Basics 7 02-07-2011 04:00 PM
tires to rims 75GMCman Hotrodding Basics 3 06-07-2009 01:46 PM
Tires and Rims ? DrBee8457 Hotrodding Basics 9 04-07-2006 03:57 PM
New Tires / Rims Gundarak Body - Exterior 2 03-27-2004 08:39 PM
tires and rims Adams55DelRay Hotrodders' Lounge 2 02-07-2002 05:14 PM
