hello all,,,,
i have a 53 buick special that has been subframed with a 2nd gen camaro subframe...im having a problem with the tires rubbing....i got a pair of olds toronado rims on it which have alot of backspacing ..and its drivable until i get into a parking spot...ive been looking at ways to narrow my wheelbase and the only thing ive found so far is FATMANS narrowed a arms...but this will only narrow it 2 inches total,,1 inch per side...is there a better solution to my problem that would give me more tire to fender clearence??? thanks,,,,,kev........ |
When faced with a car that has a sub frame installed that is clearly too wide, your choices are pretty limited. The narrowed "A" arms will help but your only real option is a set of aftermarket rims with enough backspacing to get the wheels in the proper location.
Good luck. |
i forgot to mention that it has a front steer setup...ill have to pull off the wheel and find out what backspacing i have right now......i know theres about 1 1\2 inches between the rim and the (steering arm?).....as for backspaced rims....i want to keep hubcaps on this car...so i would like to get smoothie rims....any suggestions on who can make these with the backspacing i need?
thanks alot for all your help!!! kev |
