Tires rubbing against fenders - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2011, 04:45 PM
Last journal entry: Dual 13 inch fan install
I got some pretty wide tires (295/50 R15) on the back of my '67 El Camino and there was rubbing against the fenders. I have since taken the grinder to the fenders and have removed 1/4" -3/8" of metal. How do I check the tires if the tires are still rubbing? Some way to tell the difference between the old marks on the tires an if new marks are being made.
Thank you.
Old 08-12-2011, 05:33 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Rub some chalk on the wheel opening if you see it on the tires then......
Old 08-12-2011, 05:57 PM
sqzbox's Avatar
My pipes are my music
Your destroying the fenders on a vintage 67 Elcamino just to fit fat tires on it?
Old 08-13-2011, 02:51 AM
use air shocks or go with a smaller tire dont cut the body as about poster stated
Old 08-13-2011, 06:06 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Go to a smaller tire. stop grinding on the car please.
Cole
Old 08-13-2011, 01:13 PM
bigdog7373's Avatar
Of course it's fast
How bout rolling them and flaring them just slightly
Old 08-13-2011, 01:17 PM
327NUT's Avatar
NO NO Cole!! you radius the fenders gasser style and put them big ol' Bushwhacker fender flares on it.....won't rub atol and you'll have a one of a kind El Camino......and EVERYONE wll talk about it.
Old 08-13-2011, 01:32 PM
cool rockin daddy's Avatar
What in the hell is going on? Are new rodders just this clueless? GET WHEELS WITH THE PROPER BACKSPACING TO LET YOU USE WIDE TIRES OR MINI-TUB THE THE DAMN THING!
Old 08-13-2011, 02:20 PM
sqzbox's Avatar
Originally Posted by Chucky5150
I have since taken the grinder to the fenders and have removed 1/4" -3/8" of metal. Thank you.
the damage has already been done.
Old 08-13-2011, 06:15 PM
eloc431962's Avatar
Wiki Edits: 37
True Sqz.
Cole
Old 08-14-2011, 10:58 PM
wow. Not the replies I was thinking of.
I have plans of installing new sheet metal this winter to replace all the bondo (was done before I got it), a few rust spots on the lower fender area, and some body damage that the auto transport company did for me and not paying for. This is just a temp fix until then. I already have the wheels and tires. The El Camino isn't original paint, interior, or engine.
I'll just make my own mistakes.
I'll just learn from my own mistakes.
I'll just fix my own mistakes.
Old 08-14-2011, 11:52 PM
327NUT's Avatar
Don't take it too hard pardner, if you would have said it was a temp fix till the new body work was started then you wouldn't have gotten raw-dogged so much. We have lots of guys here that don't like crapped out cars and it sounded like that's what you were doing just to squeeze some bigger weenies in there. All is good, hang with us and we'll all learn.
Old 08-15-2011, 07:31 AM
eloc431962's Avatar
Wiki Edits: 37
X2 327 that's all he had to say, info is the key when looking for answers. JMO
So as stated stick around and we will help in every area we can.
Cole
Old 08-15-2011, 12:45 PM
Always make sure you tell the whole story when posting. But you know what? What you said at the bottom of your last post is the best way to learn but we can probably make the mistakes less painful.
37 Chevy coupe tires rubbing fenders. Robert08 Suspension - Brakes - Steering 1 06-04-2009 08:46 PM
Tires Rubbing ( Back) Hou 40 Guy Suspension - Brakes - Steering 1 04-30-2007 06:24 PM
Rear tires rubbing montea Suspension - Brakes - Steering 2 03-13-2006 11:22 AM
68 camaro tires rubbing? nathanlburns General Rodding Tech 5 05-08-2004 06:57 PM
tires rubbing 53buick Suspension - Brakes - Steering 3 03-15-2002 09:39 AM
