TKO-500 or 600 in 77 C10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2010, 11:46 PM
Hi,
I have a 1977 c10 with a blown TH350....I've always wanted to put a 5sp into my pickup. Some magizine put the TKO-600 or 500 into a 1972 C10 (they make a kit for it too). Could the 72 be that much different than putting it into the 77? I'm aware that I'll need to add pedal and linkage flywheel ect ect. http://www.classicchevy5speed.com/ has the kit.. The kit for the pickups go from the 60 to 72 chevy pickup.... Any opinions welcome. The truck doesn't have an engine or tranny right now and am looking at 4.10 gears and building a 350 with AFR 180s and comp cams XR282HR-10 so wont ever go over 6000 rpm or anything but I'd like to go to the drag strips. Was thinking that the TKO-500s 3.27 1st gear with a 4.10 rear end may be a bit low so the TKO-600s 1st is 2.87. The overdrive I'd use would prob be .82. Hope that was enough info...
Thanks,
Greg
Old 03-07-2010, 02:10 AM
ericnova72's Avatar
More for Less Racer
I would call them, many places will substitute parts in kits to get you what you need. I would think most of it is the same, but I don't know about the driveshaft length, as the 60-72 is the long arm W/coil spring rear suspension, and you have a leaf spring suspension.
Old 03-07-2010, 04:57 PM
Yeah I've been meaning to give em a call just been busy. They haven't responded to any e-mails. I was thinking the driveshaft length would be different. They're site says you can measure and they'll send you one.
Tremec tko 600 mnrickster Transmission - Rearend 1 11-23-2009 04:53 PM
500 Caddy Motor in My 47 Chevy Truck WesTXmc Engine 6 08-27-2009 10:22 PM
Needed to finish TKO 600 strikingthematch Transmission - Rearend 11 02-12-2006 09:48 AM
500 hp engine or maybe 600 hp jlfvette Engine 16 01-11-2006 05:12 PM
455 vs 500? Wmarden Engine 7 10-26-2002 06:47 AM
