TKO Speedo Cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2010, 10:12 PM
boris_thespider's Avatar
TKO Speedo Cable
I picked up a Tremec TKO for my Cobra kit car project and I need a speedo cable. I'm not sure if the connection on my tranny is for a mechanical or an electric speedometer (I'm not a mechanic yet... but I keep on trying). Here's a couple of pictures of my tranny connector and the back of my speedometer. I'd really appreciate some help with part numbers for a cable that would work with my setup. Thanks...
Mike
Name:	Speedo Cable Connector_opt.jpg
ID:	43285   Click image for larger version
Old 01-17-2010, 11:09 PM
The speedometer is definitely cable driven.
I can see the transmission end as well ...
I always use a speedometer cable from a 1974 Monte Carlo with factory cruise control. The cable that goes from the speedometer to the cruise control unit ... NOT ... the cable that goes from the cruise control unit to the speedometer .
That cable is usually the right length for my projects ( mostly 1932 Fords and 1940 Fords )
speedo cable problems? 77formulabandit Transmission - Rearend 1 09-02-2008 06:02 PM
How can i extend the speedo cable. 7t2HQ Interior 6 11-19-2004 04:11 PM
