TKO or T56 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2006, 04:37 PM
comet boy's Avatar
When all else fails burn it
Last journal entry: more hiding stuff
TKO or T56
SO I am planning on building a new motor for my 65 merc comet. I plan on doing a 351W with fuel inject. with trick flow top end and roller cam. I was wondering if you guys think the T56 is worth the money? Or if I should just look into getting a TKO. I plan on around 400hp and 450ft lb of torque. SO that right there rules out a T5 which would be the cheapiest route. I want the five or six speed for the improved fuel mileage and low rpm at high speeds.
Thanks
Old 02-09-2006, 09:07 PM
TKO
T56 is OK, but if there has been any hard driving, the T56 will have suffered. Very expensive to rebuild.
Got one in the shop now that needs 4th, 5th, 6th and reverse. Parts and labor have exceeded $1500.00 and there is more to find. Be careful!
Old 02-11-2006, 06:18 PM
go for the TREMEC tko 600...
Old 02-11-2006, 06:23 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Yeah, you can typically get a TKO complete setup for less than a T56, and who really needs a 0.5 double OD?
Old 02-12-2006, 06:27 AM
Or a ZF-S542. The rockcrawlers love 'em. Stock, they're rated for 500ft-lbs, and rebuilds are available for $1-1.5K. 5 sp, single OD, available in 2wd. Unfortunately, they come with that stupid concentric hydraulic clutch slave cylinder. Gotta be a way around it, though.
Old 02-13-2006, 10:44 AM
steve392's Avatar
just passin' thru
Last wiki edit: How to title a hot rod
Last journal entry: Willys is Finished!
Wiki Edits: 2
Comet,
I'm with Curtis on this...the TKO 600 will definitely do the trick. You'll probably never have use for two overdrive ratios, especially 6th gear at .5!
The TKO 600 also has the option of two different gear ratios for the overdrive, either .82 or .64.
I just purchased a TKO 600 and went with the .64 OD ratio. Take at a look at McLeod Industries website. They sell the Tremec as well as bellhousings and clutches. Worth a look. www.mcleodind.com
Steve
Needed to finish TKO 600 strikingthematch Transmission - Rearend 11 02-12-2006 09:48 AM
th350 to t56 adrock430 Transmission - Rearend 9 02-14-2005 03:17 PM
T56 StudebakerBob Transmission - Rearend 0 11-04-2004 10:13 PM
T56 Six Speed Charles Davis Transmission - Rearend 1 04-01-2003 11:39 AM
blue print for t56 borg warner 50chev Transmission - Rearend 0 11-18-2002 04:54 PM
