Toggle Switch for Windows - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2007, 03:01 AM
Pudycat
I have an old Jag with toggle switches for most functions. I want to put in power windows but use a toggle type switch instead of a rocker style. Does anyone know if there are toggle switches that would have enough contacts to work as a window switch and if so where to buy them?
Old 03-02-2007, 04:51 AM
Wiki Edits: 31
radio shack, yeah, they make them. reverse polarity, with a neutral in the center, that's how they work, even rocker switches
Old 03-02-2007, 05:29 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Get a 3 position double pole, double throw switch..(6 contacts)
Wire the window motor to the center wiper, power on the left contact, ground on the right contact...
Then bring power from the fuse to the top left contact, ground to the top right contact, (power and ground to center wiper when the switch is pushed up) This will be "window up"...
Then from the top contacts make two jumpers to the bottom contacts in an "X" pattern, so that power is on the right contact, and ground is on the left contact, this reverses the motor, and serves as "window down"..
BE sure the center position is "OFF" or the window will always be running in one direction or the other..(up--off--down).
Doc
Old 03-02-2007, 09:59 AM
302 Z28's Avatar
Don't use the RatShak parts, most are junk. Go online to either DigiKey or Mouser electronics, you can get high quality Mil Spec switches for what you will pay at RatShak.
Vince
Old 03-02-2007, 10:21 AM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Relays can be used to control the window motor.
This permits the use of a small switch or switches if control is needed at multiple locations.
See attachment.
vicrod
Old 03-02-2007, 07:37 PM
Pudycat
thanks, exactly what I was looking for
Old 03-02-2007, 07:44 PM
excaliberprime's Avatar
Last journal entry: back for 2014
toggle switches for windows.. you can only hope no one ever hits the toggle and then gets caught in the window on its way up. true only an idiot would do this but there out the ... every where
Old 03-03-2007, 07:25 AM
I would think that a rocker would be better for this application... I'd hate to think of what a standard toggle switch lever would do to you in a accident.
Old 03-03-2007, 08:40 AM
Irelands child's Avatar
Momentary toggle switches with spring centering will work fine - such as these:
http://cgi.ebay.com/SPDT-Toggle-Swit...QQcmdZViewItem
(This is an eBay example for type only - these might be Far Eastern crapola)
Must be set up with relays as well.
Dave
Irelands child
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
toggle switch / ignition switch help help! 39chevy Electrical 4 08-18-2006 06:04 PM
Starter switch stock to modified wiring question. Kallie49 Electrical 5 06-23-2006 06:01 PM
toggle switch on 700r4 Danscam Transmission - Rearend 3 06-21-2006 04:13 AM
how to wire up a 12 volt/40 amp relay for eletric fans on a toggle switch? Blown72Camaro Electrical 4 10-02-2003 08:24 PM
