Toggle switches - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2006, 09:05 PM
Toggle switches
My '54 F-100 is undergoing some rewiring and upgrading here and there. I've added a set of classic instruments gauges in an engine turned panel to replace the junk the PO had installed.
Now I'm redoing the switches, in that the ones that came with it were a hodgepodge of different things, mostly mopar, I think.
I've built a little aluminum panel to hold six toggle switches.
One is a momentary for the starter, the others are for the headlights, parking lights, wipers, instrument lights and door popper.
I realize that the wipers will have but one speed-- that's all they had before. Besides, I live in arid west Texas. Anyone see a problem with doing this?
himmelberg
Old 10-15-2006, 09:11 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
I don't see a problem with that. Post pics on one of the sites when you get it installed. I would love to see it.
Old 10-15-2006, 09:42 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Are you relay controlling the switchgear to devices ?
IF not BE sure the contact ratings of the switches can handle the current draw of the Devices..or else first time you turn it on, or a few times after they will fail..and the heat will be very high.
Most off the shelf switch gear is contact rated for 5 amps..(unless it's big and clunky..) and that will not support a 50 amp draw of a vehicle lighting system..the weakest link now becomes the fuse..burning up and opening..the switch gear..
Wipers draw up to 30 amps depending on how they are running..
Door pops are a crap shoot as they are spike current..but depending on system, are probably well over 5 amps..even though the switch may survive..
BE sure the switches are up to the current handling task..else run a relay..
You wouldn't fuse your headlamps at say 5 or 10 amps would you? that's is what can happen with an under rated switch.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
GM/Chevy Pickup power window switches Stinkin_V8 Electrical 6 01-24-2009 09:42 PM
toggle switch / ignition switch help help! 39chevy Electrical 4 08-18-2006 07:04 PM
toggle switch on 700r4 Danscam Transmission - Rearend 3 06-21-2006 05:13 AM
Toggle switches Rubberman2003 Electrical 7 03-12-2004 01:12 PM
Need switches for the dash BigMac Interior 7 02-29-2004 06:02 PM
