Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tolerable compression without squish
Old 09-17-2008, 03:05 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Senior Curmudgeon
Wiki Edits: 326
Just a wild-*** guess, but maybe 9.0-9.5 with iron heads?????
Depends on the cam also. A hotter cam with a later intake valve closing event will allow more compression before detonation. Have you done a compression test on the motor to determine cranking pressure?
