Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tolerable compression without squish
Old 09-19-2008, 04:53 AM
k-star k-star is offline
Last journal entry: PICTURE TEST
quench
You will be fine..
Something to think about,,
Make sure you calculate the amount of mateial needed to reduce the chamber 14cc to get your compression of 9.5. The intake side of the head will also need cut, you will probably need another set of pushrods because of the shaft mount rockers. You will probably need to work the intake holes also. When you add all this up it may be a better deal to get the correct pistons.
If it's a fresh engine i would buy the pistons before i choped the heads/intake JMO.
Keith
