Tony - question about new control arms - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2003, 07:40 AM
Tony.
hey your gonna have control arms for 61 chevys soon right???
will you have upper and lower arms?
how much drop will the arms give? will the drop be different for shockwaves/bags?
will they be able to be used with aftermarket spindles w/ dics brakes?
will they bring the wheels inward at all?
thanks.
bob
Old 11-19-2003, 07:21 AM
Bob....
Yes we will have tubular's available for the 58-64's hopefully here in mid December. A control arm built for Air Ride is not considered to be a dropped control arm like a coil spring arm. Our arms will be close to stock width and will have the geometry corrected for a lowered ride height. They will also be designed to accept the factory spindle, so any spindle that is designed as a fatory replacement should be fine. You may want to hold off on purchasing a set of dropped spindles until you get the arms in the car. You might be plenty satisfied with how low she gets out of the box.....
