Too late to heat cure paint? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2012, 06:38 PM
Hi guys! Just wondering if there was a time window after you spray something with a paint that requires heat to cure it that it must be done in? I painted the engine fan shroud and fan with High Heat Rustoleum about 3-4 weeks ago. I spoke with the tech manager at rustoleum and they told me that the paint needs to be cured for an hour at 350 degrees, even though there's no mention of it on the can. I'm wondering if it's too late or if now that so much time has gone by it may have cured on it's own? It's a flat black and grey respectively and I'd like to go over it with some engine enamel but I'm afraid if this isn't cured first it will all come off...
Heat curing paint 2 weeks later. Is it too late? RetroJoeG Hotrodding Basics 11 10-09-2012 10:23 AM
Filler cure time before epoxy or paint? ka24deroadster Body - Exterior 1 04-17-2009 05:18 AM
paint I can scuff n paint after cure period Slickriffs Body - Exterior 4 08-17-2008 06:15 AM
paint cure questin? coupe33 Body - Exterior 1 01-12-2008 12:01 PM
Paint Cure Time - How Long Should You Wait bigbrowndog Body - Exterior 3 04-14-2006 08:36 AM
