Too much camshaft!? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2007, 04:15 PM
pi71's Avatar
Too much camshaft!?
i just got a 66 olds with a 350,tunnel ram 2 holley 4barrel carbs(450cfm) the previous owner stated he installed a 270 comp cam. the engine runs good but very rough at idle and most of the time sputters thru one of the carbs when you try to take off from a stop..i really just want a reliable cruiser, I like the looks of the tunnel ram and 2 fours but the rough idle is not very street friendly, what cam do you guys suggest. its a 4 speed with 3.08 gears. Or should i just loose the tunnel ram and 2 fours as well...?? im more of a cruiser than a racer..
Old 03-04-2007, 04:20 PM
DeathRattle's Avatar
Some Punk Kid
I bought that cam for the idle. Its supposed to idle rough. 224 duration @ 50. .470 lift. It's still a pretty mild cam. They recommend a 3.73 rear gear for it.
About the sputtering. Does the exhaust smell like the engine running really rich?
Old 03-04-2007, 04:24 PM
BOBCRMAN@aol.com's Avatar
That cam and induction system will not work well under 3500 rpm.
If you want the sound, keep the cam. If you want drivability go to a street intake with a vac secondary 650-750.
Heavy car 3.08 gear. The only thing you have correct is the stick trans.
Old 03-04-2007, 04:27 PM
pi71's Avatar
yes the exhaust smells very raw, like gas.
Old 03-04-2007, 04:30 PM
Some Punk Kid
Bob is very right. Your motor is over carbed. You could tune em to lean em or just pick up a dual plane manifold with a 650 vacuum carb.
OR
Swap rear gears and keep the RPMs way up
Old 03-04-2007, 04:41 PM
pi71's Avatar
So the cam with work for what i want, and i should either tune,or lean, the ones i have, or go to a single carb, and intake,, with a 600-650cfm carb and some lower gears. sounds easier than what i was gonna tackle.
Old 03-04-2007, 05:25 PM
Some Punk Kid
Just a FYI-the RPM range for that cam is 1800-5800.
Old 03-04-2007, 06:23 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You've got Holleys, does one or both of them have a blown power valve?
mynuffinfutsitch's Avatar
put u a progressive linkage and youll be fine
Old 03-04-2007, 06:47 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Originally Posted by F-BIRD'88
It's all in the set up of the distributor and carbs.
Your tunnel ram will idle and drive fine once properly set up.........
.......Leave the vacuum advance disconnected for now.
good post
Old 03-04-2007, 07:42 PM
pi71's Avatar
no idea i just got it home today. ill check.
Old 03-04-2007, 07:56 PM
pi71's Avatar
update: It has a mallory unilite dist. and a Holley blue electric fuel pump, Too much gas ? not enough timing? does it really need this caliber fuel pump? i didnt see a regulator..
Old 03-04-2007, 08:20 PM
pi71's Avatar
Ok , i think i want to remove the whole intake setup and go with a single carb, while im there ,I might as well put in the cam i want. so thats where you guys come in. it has a comp 270 cam, with 224 dur/470 lift. what would be a better cam for my application? 66 cutlass is a pretty heavy car (3600lbs) and im more of a cruiser not a racer. i dont really care for the rough idle but a little more power from idle to 1500 would be good. what do ya think? it is a 4 speed car and i will prob go from the 3.08 to 3.42 gears soon. thanks guys. (anyone looking for a tunnel ram setup?
Old 03-04-2007, 08:32 PM
Blazin72's Avatar
Wiki Edits: 19
That cam should work just fine for your car, with the exception of maybe adding a lower gear like a 3.55 or maybe even a 3.73. The engine probably just needs to be tuned and have a few bugs worked out of it. Start with simple things like performing a full tune up on it, checking/setting the timing, cleaning and repairing the carbs if needed, etc... Try getting what you've got to work before you start tearing into things.
Old 03-05-2007, 04:15 PM
F-Bird . . . . . .
Let us know if you get away with this swap . . . .
Pat
installing a roller camshaft chevyelc81 Engine 2 12-16-2012 11:36 AM
Rotella Motor Oil boss350 Engine 14 04-18-2007 12:00 AM
1998 Chevy Venture camshaft kberly54 Engine 2 07-14-2005 09:09 PM
How to choose correct camshaft Drag1racer Engine 0 07-08-2005 05:04 PM
454 CAMSHAFT GROOVE 64VETTE Engine 4 01-18-2003 01:32 PM
