too much compression - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2010, 05:40 PM
The debate continues... How much compression is too much compression for pump gas on a Iron headed Small block chevy with a 276/284 duration cam??? I have 10.7:1 with no detonation and my buddy wants to go 11:1.. I think it's too much...
Old 08-18-2010, 06:01 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You can run on pump gas with 11.1 comp. I do it all the time you will have to properly adjust everything just like you would anyway but you can run on it. At-least 93 octane JMO. But i would say 11.1 is pushing the limit pretty close. IMHO.
I am sure someone will say no way but i know for a fact you can maybe not on all setups but for the most part you can. JMO You might want to through in some good additives every now and then but it will work. But it would probably perform better on a little better fuel though.
Cole
Old 08-18-2010, 06:14 PM
With Iron heads??
We have 93 octane here and that's pretty much all we use anyway. A little more when we get fuel at the track..
Old 08-18-2010, 06:16 PM
eloc431962's Avatar
Wiki Edits: 37
Yes with Iron heads, I am running a set of 230 Dart Iron Eagle heads on my set-up does fine on pump gas.
Oh by the way which Iron Heads is your buddy going to be running anyway ?
Cole
Old 08-18-2010, 06:23 PM
ericnova72's Avatar
More for Less Racer
11-1 is certainly right in the edge for something that isn't reverse cooled, fuel injected, and has knock sensors.
I've done it too, just like Cole. You can't do it with a cam that small if that is the advertised duration #'s that you posted, you need the @.050" duration numbers to be up near that, to get away with it. Chamber shape plays a part too, you can't do it with typical smogger heads
Old 08-18-2010, 06:42 PM
He has the World Sportsman II's with 200cc runners and they've been ground to 56cc chambers. The @ .050 duration numbers are 233/241 on the cam.
Old 08-18-2010, 08:05 PM
ericnova72's Avatar
More for Less Racer
Not going to work, not enough duration, needs 246+ @ .050" on the intake side.
Old 08-18-2010, 09:18 PM
Originally Posted by F-BIRD'88
I take it he has the heads and wants to sell them to you and make your 10.7:1 motor 11:1.
www.ramairbox.com Make the engine process more cooler, dense, air.
Easy to install on a 1969 Nova.
NO, I have my my own similar heads but mine are 64cc's. My motor is staying the same, it works well!!!
I like that ram air box, pretty cool, but I think it would defeat the cowl hood I got, or I could have the ducts face the opening.... hmmmm
Compression question for the Pro engine builders.. Axelrod Engine 14 01-16-2007 11:29 AM
351 windsor running rich ???? ve3ham Engine 19 08-08-2005 01:48 PM
Compression 4x4vandale Engine 5 10-09-2003 12:59 AM
High compression ratio pistons invincible Engine 6 09-22-2003 11:16 PM
compression calculation gabledawg Engine 4 03-06-2003 04:13 PM
