Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - too much or enough motor
Old 12-05-2012, 12:25 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
That cam and CR are getting close to max for pump fuel with iron heads.We can ask tech to check the cr for you. We need exact cam specs,intake center line and lobe separation.You might need a bigger cam? I use a bigger cam in a small block with 3.50 gears.I wouldnt want to spend a lot of time in stop and go traffic,unless of course I was at the front at every red light.
My CR is 10.75:1 with aluminum heads
