Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - too much or enough motor
  #38 (permalink)
Old 12-06-2012, 09:13 AM
ap72 ap72 is offline
How fast is fast enough?
If you want velocity (which isn't always a good thing) then you may want to look into methods of fillin gyour ports with epoxy. Stock BBC ports (more so than SBC ports) can benefit from adding some material in the right places. Its very important to do it properly though and use the right material as you don't want it coming loose and going into your cylinder.
