Too much fluid? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2005, 12:00 PM
Too much fluid?
What would happen if you put too much fluid in the tranny?
Old 11-12-2005, 03:51 PM
Too much fluid can cause the fluid to foam, leading to erratic shifting, oil starvation, and transmission damage. This may also force the fluid to leak past the transmission seals.
Th-350 ran with no fluid WakBordr7387 Transmission - Rearend 36 05-26-2005 04:24 PM
toploader horrible after fluid change 65fbmustang Transmission - Rearend 4 11-21-2004 08:22 PM
When to use Silicone Brake Fluid jpd37 Suspension - Brakes - Steering 4 04-17-2003 06:02 PM
how low on fluid (TH350) before it quits moving? HotRodF100 Transmission - Rearend 4 10-11-2002 06:34 PM
Dot 5 Silicone Brake Fluid?? Yes or No ?? Jim Weeks Suspension - Brakes - Steering 18 04-15-2002 06:22 AM
