Too much foreplay - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2009, 05:17 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
Too much foreplay
Or is that freeplay? Anyway, I have about 2 inches of pedal travel before the brakes work. It's a 54 ford truck with disc/drum setup. Frame mounted 7 in booster/MC. PO says it was a complete kit. I have adjusted the rears, bled the system, etc. Brakes seem to be fine when they finally start working.
I'm thinking the booster to MC rod may be the cause? Wouldn't that be set correctly in a kit? Anything else to try before I pull that booster? Without a hoist it is going to be a nasty job.
Old 02-06-2009, 06:29 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
sounds like you have everything.i ran into this once before and i got a adjustable m c rod .fixed it.hope this helps. cole
Old 02-09-2009, 06:29 AM
31 five window
Last journal entry: Moving along with patch panels.
Do you have a combination valve or just an adjustable proportioning valve?The combo valve sends fluid to just the rear for a split second before the front because they take more fluid to work .When you have 4 wheel discs it is not needed but it is recommended for drum/disc combo.
Old 02-09-2009, 05:29 PM
oldguy829's Avatar
Wiki Edits: 88
too much play
PO did the brakes. It appears to be a combination valve. Definetly not an adjustable proportioning valve.
