Too Much Heat
I need to insulate the interior of my 1947 Ford Coupe. The insulation under the carpet is a bubble wrap type insulation. But the firewall, floor board, transmission hump get extremely hot in this Texas weather even with A/C on.
I have billet interior hardware and the console plate alunium gets so hot you can't put your hand on it. I've been told Dynamat, Hushmat, and even to go to Lowe's for insulation and to use coating of the type used on roofs of mobile homes will do the trick. Can anyone point me in the right direction. Thank you. |
Check this out:http://www.lobucrod.com/
There is a ton of info on this subject here, but you need to search for "sound deadeners". That will lead you to a lot of the information you are looking for. One warning: Roofing products that are available from the home improvement stores, like Peel & Seal, are asphalt based. If you are getting that much heat, you will need something that is butyl based. It will be more expensive, but it will work better. Good Luck.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
Too hot ???
Hi,i took white LATEX paint,mixed it with MICRO-BALOONS from AIRCRAFT SPRUCE.COM,sprayed it with a undercoat type gun i bought on flea bay for $9.00,2coats,on everything including roof,then went to home depot,bought a roll of the silver,wrap,installed it inside my 48 ford coupe,(all places i could reach),on the doors also,with the door outside in the sun ,the outside of the door,was 145 degrees,inside the door was 95 degrees.quite a temp drop...
| Recent Interior posts with photos |
| Heat and air | 61panhead | Hotrodding Basics | 4 | 01-07-2011 04:50 AM |
| heat lamps ok for painting heat source? | matt167 | Body - Exterior | 4 | 11-12-2008 04:55 AM |
| Need Some Heat Help | oldsmo | Electrical | 5 | 05-06-2006 10:36 PM |
| A/c/heat | Erk | Interior | 3 | 02-24-2004 01:43 PM |
| Heat and Air | 53Z | General Rodding Tech | 3 | 04-09-2003 04:03 AM |
