Well yes,there could be some problems with that,how big of pan do you have,and what sort of oil do you have in it,also,is this a roller cam motor? Its pretty tight yet,how much pressure do you have at an idle and at what temp,and are the pressures you gave at a rev? It doesn't necessarily sound like a bad thing.
249-CL11-250-3
Xtreme Energy XE284H Hydraulic Flat Tappet Camshaft Lift: .574''/.578'' Duration: 284°/296° RPM Range: 2300-6500 Thats the Cam that was used in the motor. As for the oil pan, its a 5 quart.. and the only oil pan I could find that wouldn't hit on the steering. The oil that we used was Valvoline 10-w30. When first started at a higher idle (maybe 1200 rpms) the oil pressure was 95-100. As the motor was heating it, it wasing being sped up and slowed down and the pressure kept fluctuating between 85-95 poiunds. Thanks for your response. Rob |
During cam break in you should of had the RPMs in the 2000-2400 RPM range.
Before you worry about too much pressure I would change the oil and the filter (should be done right after cam break in). Right now you have assembly lube (if you used it) and other things floating around in your oil. The main thing that would cause your oil pressure to be so hign is you bearing clearances. Do you remember what they were set at? Sounds to me like they are on the tight side, with that and a high volume pump your oil pressure will be high. Tthe only problem are the possibilty of having busted oil filters, pushing the O ring out, and heating up the oil. After you do an oil and filter change and run the engine for a while, see how the pressure acts. If the pressure doesn't settle down I would probably pull the pan and change the oil pump/spring. You really only need about 10psi per 1,000RPM (meaning at 6,000RPM you need 60psi of oil pressure). ROyce |
A couple things,my one concern was you thrashing your dist and cam gear,but I would guess you didn't use a bronze one because there was no need with that cam so your good there,also,you run the risk of sucking the oil out of the pan at high rpms and hurting the bearings"cant drain down fast enough",it could all end up on top,also,if you feel the need,you could put a lighter spring in the pump,some come with one,high pressure and high volume are two different issues,I am getting ready to put the same cam in a 454,how does it sound? do you like it? I would stay with a lighter oil for awhile.
Also like camaroman7d says about the filter blowing,that would fall into the"bad thing"category,they have filters with high burst pressure ratings you might want to think about. Last edited by rifraf; 11-20-2004 at 12:52 PM. |
