too much power in my power steering! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2005, 12:27 PM
I just finished the front clip on my Stude and am having power steering problems. I have an early model GM pump attached to an 80 camaro box. The steering wheel and wheels turn on their own at idle. Somehow there is drag coming from the pump I assume. Any thoughts on a fix for this? Also the power assist is too strong, how can I lessen the power assist?
Old 02-19-2005, 01:16 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
power steering
BB pump or SB pump? Does a Camaro use a power steering control valve?
Old 02-19-2005, 01:17 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Common problem in light weight rods. You need a prssure reducing valve that easily inserts into any GM steering pump.
Old 02-19-2005, 10:12 PM
It's a small block pump. The pressure reducing valve, where can I get it and what pressure do you reccomend. I have a 49 Stude pickup with an 80 camaro clip and a 327.
Old 02-20-2005, 05:05 PM
Sorry did not read your reply correctly. Thanks for the link. I thought the reducing valve was only necessary on a gm pump to mustang II setup. Did GM make pumps with different valves or are they all the same?
Old 02-21-2005, 08:17 AM
johnsongrass1's Avatar
Race it, Don't rice it!
A few are different but most arethe same. You can unscrew the pressure valve and see if it has a washer under the spring. If it does remove it and try it. If you don't like it then upgrade to new valve.
new power steering pump questions HARVICKx29 Suspension - Brakes - Steering 3 09-05-2005 03:22 PM
Power steering pump hitting box tjh211 Suspension - Brakes - Steering 7 11-16-2004 04:29 PM
Swapping to big block chevy low77ride Engine 5 09-15-2004 09:30 PM
Power steering chatter in steering wheel jpd37 Suspension - Brakes - Steering 10 05-19-2003 03:59 AM
Power Steering Pump Problem... IWasBlown Engine 1 04-07-2003 09:03 PM
