Too much time after rebuild?
I have a 350 SBC that was rebuilt about 8 years ago. It sat, covered with a few moving blankets in the corner of the shop till installation. After market Comp cam, 9:1 compression, All Star distributor, Edelbrock intake, 650 Edelbrock 4 bbl. I am finally getting the car sorted out (my 36 Ford) but it has issues. At low acceleration, it pops, bogs down, sounds like a flat cam. Get the rpms up to around 3500 and it levels out, runs pretty good. I'm getting various opinions on this: Lifters sticking, a flat cam, rust in the cylinders, Loss of compression from the rings not seating. I have had the valves run twice, carb rebuilt, and added a quart of some Rislone stuff to free the lifters. Granted, I have only run the car about 20 miles, should I run it out and maybe wring it's neck a little? It idles fairly well, and seems to cruise along pretty well at about 60 mph. I don't want to tear this thing up, it's too dang hard to get the engine out now. Also, all plugs are firing.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
Bogie |
If the timing hasn't been sorted out yet, I'd suggest a baseline of 14º initial timing, about 36º total (not including vacuum) all in by about 2600 to 3000 RPM. Use a vacuum advance supplied w/manifold vacuum to add to the initial timing- no more than 10º is usually needed. This set-up will be sufficient to remove the timing curve from being the problem, IMO. A couple things to make setting the the timing curve up, is a vacuum advance limiter plate, Crane #99619-1: 99619-1 INSTRUCTIONS. If needed, you can instead use an ACCEL #31035. It is an adjustable vacuum advance can for GM HEI that allows infinite adjustment to BOTH the amount and rate of advance. Comes w/instructions and tool. Be sure the wires aren't run parallel to one another for long stretches (can induce cross firing) and that the cap and rotor are good. If using an HEI distributor, be sure the dist. is getting full battery voltage, w/no resistor wire or ballast resistor in the power wire. The carb may need tuning of the accelerator pump shot and step up springs/jets/metering rods to suit the engine and vacuum made w/the cam. Edelbrock has calibration kits w/the necessary parts to tune the carb. |
Thanks for the advice, this gives me a few new ideas. The cam is a comp 280, quite a bit of lift, 480. I've checked the wires, I will check again. I will have to check the vacuum. The distributor is an All Star, a HEI type, takes the smaller dist cap, I have a tight squeeze. I will look more into stats for it. The miss is heavier with a load, it doesn't miss much at all when idling and zapping it out a little. Advance issues? Cobalt, some good advice, I will probably have a friend get involved with some of your suggestions, I really don't have the expertise to mess with this. The guy that rebuilt the carb should be willing to dial it in, I don't want to fry any engine parts with lean mixes. Thanks again, hopefully I can get this sorted out. This car has come a long way, now I need to get dialed in. Dan
With the engine at an idle, the step up springs should allow the metering rods to remain all the way down. If the rods are able to lift up too soon (step up springs too stiff), this will cause a too rich air/fuel mixture- the step up springs work something like a power valve in a Holley, or a power piston in a Q-jet. Even the plugs could be contributing to some roughness if they're not getting fully up to temperature and are seeing a good bit of time w/the engine at an idle- so be sure the plugs are nice and clean. I'm sure you already have one, but in case you don't here's the Owners Manual. You have the AVS Edelbrock 650, right? |
Did you break in the cam properly? And what kind of oil went in it? Did you add any ZDDP, GM EOS, or Break-In additive?
For the 280H cam The distributor needs to be recurved. 24deg at idle 34-36deg at full advance.
shorten the mech advance to around 10-12deg Then vacuum advance should be limited to around 10-12deg. Check for accurate timing tab location using a pistons top. All aftermarket timing tabs are off some. Use a 4" rated carb power step spring. Check the voltage to the distributor. 12v + look for manifold vacuum leaks. |
I agree. Start up your motor and get an oil can and squirt a bit on the edges of the intake gaskets. If the oil gets sucked in then there is your problem. Another way to check is to start it and let it idle and spray starting fluid around the edges of the intake, if the motor revs up then that means it sucked the ether in and you have a vaccuum leak. The problem could also be at the base of the carburetor. If there is nothing there then I would start looking real close @ timing and the distributor. You might also double check rocker adjustments. Last edited by 65smallblock; 08-10-2010 at 12:42 PM. |
It sounds like your having a similar problem I had with 305 with an old rochester 2bbl; when i gave it gas it would bog down then rev up very slowly while making a popping, crackling kind of noise out of the exhaust. I got a new carb, and problem solved. Maybe try cleaning it first though before you waste you money.
I would try switching out to a known good working carb/fuel filter to see if that helps.Next i would be getting an advance curve kit and follow F-Bird 88's advice.
first off, thanking all of you for the help, I am not an engine guy.
Did you break in the cam properly? And what kind of oil went in it? Did you add any ZDDP, GM EOS, or Break-In additive? Yes, ZDDP, if I remember right. I got the bottle when I had the engine built 8 years ago, the guy that broke the engine in is a good wrench. Valvoline oil. I also added a bottle of Rislone recently to see if that would help any stuck lifters or seat the rings. I had the carb built by one of the better shops in town, it too had sat for about 8 years. I am going to bring it (the car) into his shop Friday for some tuning, also to see if there is anything else that is not right. No vacuum leaks, valves have been adjusted twice, I have fresh gas, 89 octane, I am leaning toward the timing end of things here, I should find out Friday. The shop I am taking it to has drag racing experience, do much of the race engine building in the are, pretty sharp guys I have known of for many years. I will keep you posted. Thanks again, Dan
I just got my car back today. There was a fried plug wire, some carb adjustments, valves were re-adjusted (all were ok), one small vacuum leak and still had a terrible miss after it warmed up. To make a long story short, the brand new Allstar HEI distributor was bad. Replaced it, it runs like a top. Thanks to all for the help, you could say the timing was the culprit. Dan
| first time rear-end rebuild | biscuitville | Transmission - Rearend | 4 | 02-24-2010 09:12 PM |
| Its Time..... | ZMaster | Introduce Yourself | 3 | 09-11-2006 11:28 PM |
| Time for a rebuild......... | 53_belair | Engine | 1 | 08-14-2006 08:32 AM |
| Time window after primer,body filler, color ,clear | BIG DOG | Body - Exterior | 3 | 07-20-2006 09:13 PM |
| Time for a rebuild? | 2wld4u | Transmission - Rearend | 2 | 10-25-2003 05:16 PM |
