too old of an olds - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2012, 07:17 PM
Mr.Fixxit's Avatar
too old of an olds
Hey guys, I got this 1990 oldsmobile cutless in my bay. The issue is the car has terrible emissions when going through inspection, the car drives great and the 3.3 v6 runs smooth. Its got about 98k on the clock. I want to test the obd and see what codes flash. I think it could be a bad o2 sensor or the cat is filthy and needs to be replaced. Anyone know where i can get a pin chart for the obd connector or where i can find a chart of codes to look at while i test the obd? And if you guys could throw up any info on the cars problem, im all ears.
Old 10-05-2012, 08:29 PM
LATECH's Avatar
The top connector is OBD 1 . If you jumper terminal A to terminal B and turn on the key, you will get flash codes from the check engine light.
ID:	68283   Click image for larger version
Fact is stranger than Fiction
olds buick 231 p/s pump onto an olds v-8? fast68 Engine 3 03-04-2010 07:07 PM
olds wants to know knap02 Engine 1 07-05-2008 07:54 PM
71' 350 #7 olds heads on 79' 403 olds Rough-Rider Engine 5 01-22-2007 05:04 PM
350 Olds Engine on Any Olds 7skylark6 Engine 8 12-12-2003 07:17 PM
70 olds axle bastard Hotrodders' Lounge 2 06-25-2002 06:40 PM
