Took sun roof out of 84 Cutlass cross members missing will roof rattle at high speed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2009, 06:18 PM
heathj1's Avatar
Which way to the swap meet??
I bought a 84 Cutlass it had a retractable sun roof. It leaked so I was going to take it out and glue or weld a patch in hole. I got it out today and saw that all the cross members in the roof were cut out of roof to make room for sun roof. Will the roof rattle when I go down the interstate at 70 mph? I can push down on roof and it flexes pretty easy. Can I patch hole and then glue weld strips to help roof firm up?
Anyone ever had this type of problem before?
Old 04-14-2009, 07:23 PM
302 Z28's Avatar
I can honestly say that I have never heard of anyone doing this. Gluing a filler piece will not work, that hole left by the removal of the sun roof needs to be welded shut with sheet metal. What you need to do is find a like vehicle in a wrecking yard to use as a donor. That way you can get the exact piece of sheet metal that goes where the sun roof was. It will match the curve of the roof where if you used a piece of flat sheet metal you would have to put a slight bow in it to match the roof.
Vince
Old 04-14-2009, 08:00 PM
heathj1's Avatar
Will roof warp if I weld in patch?
Old 04-14-2009, 09:23 PM
302 Z28's Avatar
You must go very slowly moving from side to side in small increments. Allow lots of cooling, do not weld in one place too long to prevent over heating. This is best done with a MIG or TIG welder.
Vince
Old 04-15-2009, 09:41 AM
Guys, I wouldn't even spend five minutes welding up that hole or even thinking about it, I would replace the whole skin. Replacing the skin would be MUCH easier and you would end up with a much better end product.
If you remove both front and rear windows and roof moldings. Then clean the sealer out of the gutters and pinch weld areas in the windows. The hardest part is melting the lead out of the sail panel seams. Clean them down to bare metal. You will see the spot welds that are holding the roof on. These spot welds need to be drilled out. If you can, drill them from the bottom and don't go into the roof metal, just drill through the one layer of metal right in the middle of the weld. I like to look at this as "Unbolting" the panel, you simply drill out each weld like you were removing a bolt, it really is no difference at all. At each corner of the roof there is a MIG weld or it is Brazed I forget, but those areas need to be cut with a cut off wheel or in the tight spots you can use a burr cutter. Remember, you can grind the living crap out of the adjacent panel, you won't be using it anyway right? You could even cut with a cut off wheel along the spot welds and then after the roof is off the car separate that last bit. But it is best done while the roof is stable on the car and not sliding around on the floor of your garage. Then on the car you are putting it on, you will want to remove the roof by drilling out the spot welds from the top, drilling through the panel you are throwing away. Again, destroy the panel you are removing, grind any welds on THIS side and do what ever it takes to the panel you are throwing away so you don't damage the fresh metal below it. I use a long Snap On tools gasket scraper to slip in between the sheets of metal to separate them. After you have the panel removed you need to take a hammer and flatten out the areas that you have drilled out the welds. Then grind with a little 3" 50 grit disc any little pieces of metal that will interfere with the "new" roof laying flat on the mating surface. Then using a "Roloc" disc clean that mating surface GOOD on both the "new" roof and the car. Then brush or spray a light coat of weld through primer. Let it dry REAL good before you do any welding. And DO NOT apply it heavy, it will be a mutha to weld through.
Pay attention to any sealant or "foam" cushions that the factory put between the panels to support the roof skin. If they got damaged as you separated the panels, you will need to put something there like a thick urethane sealer or something to replicate the soft, NOT stiff support the factory had. BE CAREFUL that you don't have too much, or that you don't have two factory layers (from the "old" roof and the "new" roof) that could cause you LOADS of trouble with fit of the "new" roof.
Now, if you have done a nice clean job of removing the roof, there are only a few holes in it. You can do one of three things to reattach it. You can glue the seams at the gutter and at the window pinch welds and only weld the sail panels and at the corners of the roof. This is how I would do it if I were doing it at home and didn't have the spot welder I do at work. Or you could weld the sail panels and corners with the MIG and then bring the car to a shop with a spot welder to do the pinch welds. Or you could plug weld with the MIG all the pinch welds. I have to say this is HUGE overkill and gluing is the way to go.
If you go the gluing route, forget the part about weld through primer, you will only want it on the areas you WILL be welding. Depending on the brand of panel adheasive you use, you will want bare metal or epoxy primer where the surfaces will be bonded.
Don't ask about bonding the sail panels, you REALLY do need to weld those.
I am sure I left something out, but that is a start.
Old 04-15-2009, 11:56 AM
speede5's Avatar
go fast, turn left!
What are you going for with this car? Is this a daily driver, ground up resto, or a car that will soon be for sale. I may get shot for suggesting this but what about a bit of a spin on Brians idea, which while being the right way to fix it may be more work than the car merits. What about finding a roof skin from another car and capping it. Overlay the new panel and weld up the seams. A thin coat of acoustic sealant in between the panels would prevent noise and corrosion.
you are going to want those braces as well, They put them there to prevent oilcanning, just like you suspected.
Old 04-15-2009, 01:36 PM
interesting read that.
i have the same dilema with the s10. it has one of those plasticc sunroofs fitted which everyone had over here in the 80s.
ive got a roof off a donor car which were going to try and use.
any other tips are most welcome.
Old 04-15-2009, 01:49 PM
scrot's Avatar
This sounds like a good idea. It will certainly be stronger.
Will the body lines and joints line up?
Old 04-15-2009, 05:43 PM
heathj1's Avatar
I bought this Olds Cutlass to put back together and put a 496/turbo400 9 in ford in it. Going to make a street strip car out of it.
Old 04-16-2009, 07:28 AM
speede5's Avatar
go fast, turn left!
Actually I was thinking about it and you would have to trim the panel right at the bend and weld it all around. You wouldn't be able to fully cap it because you would want the panel to be right tight to the existing roof. It would still work and in theory your roof would only be about .060" higher than stock. I just thought you may want an option that didn't involve removing windows, which can be hit or miss on the front. If you already need a new windshield though Martinsr has given a great synopsis on the best way to fix it.
Meaning of the iron cross? FASTCHEVY Hotrodders' Lounge 15 03-05-2004 11:01 PM
