tool for grinding in tight places - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2004, 07:18 PM
cboy's Avatar
Last journal entry: Finished
I'm looking for burrs, rasps or stones for grinding metal and welds in tight and hard to get at spots. Will these carbide burrs do the trick or is there something better or cheaper.
http://www.harborfreight.com/cpi/cta...emnumber=38692
Always learning...and sharing what I've learned.
Old 11-27-2004, 03:40 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
would that set be good for porting heads?
Old 11-27-2004, 06:27 PM
adtkart@aol.com
I use those types of burrs all of the time for grinding welds and such. I got mine at a car show in Carlisle for about $7.00 each
Old 11-27-2004, 06:54 PM
Old enough to know better
Small, shaped stones will be cheaper but will not have nearly the life of the carbide tools. The carbide is better for non-ferrous metals too. It won't load up like a stone will.
Old 11-29-2004, 04:00 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Standard abrasives head porting link
Here's a link that will help you out.
http://www.sa-motorsports.com/diyport.shtm
It'll give you the ins and outs of head porting and air flow. Good read!
Old 11-30-2004, 11:13 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Dewey-
Those will do,,,, for limited grinding. They are a cheap knockoff. The real tool, like from a machine tool supply store will last much longer. Those work pretty decent.
Jeff
Old 10-13-2006, 08:35 AM
Scode68's Avatar
Ed S.
I know that this is an old post but I have a question. I have some carbide burrs that I use for porting and was thinking of using them for grinding down some wells in tight spots. My question is, would I use them dry or lube them like when Iím porting?
I would think any lube would dirty up things but extend the life of the burrs.
Old 10-13-2006, 11:16 AM
astroracer's Avatar
I get my Castrol Cutting Wax from Enco...
http://www.use-enco.com/CGI/INSRIT?P...&PARTPG=INLMK3
6 bucks a tube. Buy a couple, cut them in half and put them by the band saws, drill presses, etc., etc...
Mark
Old 10-13-2006, 11:53 AM
Scode68's Avatar
Ed S.
Iíve used trans fluid in the past and WD40 when I was in a pinch. The trans fluid seems to work pretty well but didnít want to have to get things all sloppy in case I had to do some more welding. I would also like to paint the areas when Iím done.
Iím welding a shock tower into a 68 Mustang. The old one wasnít rusted but crack so much that it had to be replaced.
Old 10-14-2006, 07:11 AM
cboy's Avatar
Originally Posted by Scode68
My question is, would I use them dry or lube them like when I�m porting?
After getting that set of burrs (see original post) I have used them dry to grind all sorts of welds. Except for busting the head off of one of them, it seems to work pretty well without any lubricant.
