Tool to install crank sprocket on a SBC? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-02-2008, 09:42 AM
SSedan64's Avatar
Originally Posted by v8hed
Has anyone got a pic of this set-up, just so I'm clear? Is there any danger of stripping the crank snout threads by doing this?
Thanks.
You shouldn't have any problems with stripping threads with this method.
  #17 (permalink)
Old 07-02-2008, 10:46 AM
engineczar's Avatar
Originally Posted by CNC BLOCKS NE
How does that work on a 283 or 327 crank that has no threads for the installer?
Seeing as I've never built a 283 or a 327 I wouldn't know so I guess until I do then I can't call myself an engine builder.
BSE Racing Engines
  #18 (permalink)
Old 07-02-2008, 02:25 PM
You must be an engine assembler LOL!!!!!!
  #19 (permalink)
Old 07-02-2008, 07:40 PM
i have seen more than a few crank gears split because of tapping them on. as carl said heat it up and slide it on.
sam-missle
  #20 (permalink)
Old 07-03-2008, 12:06 AM
On our blower engines we build we use the Shaffer/Wesmar gear drives and they highly reccomend heating the gear and sliding it on as it does have a lot of interfearance as it takes a lot to get them off.
  #21 (permalink)
Old 07-03-2008, 05:45 AM
540z's Avatar
Brute force and ignorance.....
For installation on a non-threaded crank snout, heat the gear as mentioned above, oil the crank snout and quickly tap into place using a piece of thick walled brass tube or even PVC tubing. Just make sure that there's nothing to interfere with the installation such as burrs or a screwed up key or keyway. Whenever I have a 283 or 327 crank re-done though, I have the crank nose tapped for a harmonic balancer bolt.
TR
Oil out the crank snout on SBC... XNTRCI-T Engine 3 03-14-2007 12:54 PM
SBC Vibration damper install question dirtydave Engine 6 07-24-2004 09:30 AM
SBC timing chain cover Install Iroc'o Engine 17 06-17-2004 02:47 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
piston to crank install Nos Hotrodders' Lounge 8 09-18-2003 02:14 PM
