Tool to install crank sprocket on a SBC? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2008, 05:20 PM
v8hed's Avatar
AK427
In the process of swapping my cam and may swap-out my timing set at the same time (although this one has only covered 6k miles). Is there a tool to re-install the crank sprocket? I have a 3-jaw puller to get it off, but have no specific tool to get it back on again.
Thanks.
Old 06-29-2008, 05:37 PM
Frisco's Avatar
Glad To Be Here
The crank sprocket should be a LIGHT tap fit and can be installed without any special tools. It should actually slip over the crankshaft and start over the woodruff key before any pressure is required to complete the installation.Tap lightly going around or alternating sides of the sprocket staying close to the crankshaft and away from the sprocket teeth. A pipe that can be slipped over the crankshaft with minimal clearance can also be used to apply the "tapping" force more evenly. Be sure that the sprocket is fully seated (bottomed out) against the shoulder of the crankshaft.
Old 06-29-2008, 05:39 PM
v8hed's Avatar
AK427
Great, thanks
Old 06-29-2008, 07:33 PM
We use a propane torch warm the gear up it will slide right on. We just had a crank in the shop to balance that some beat the gear on with a punchm Ahh we got a good laugh out it any ways.
Old 06-29-2008, 08:03 PM
31 five window
Last journal entry: grill and rear end
You have to know when to tap and when to beat. The crank sprocket is a tap.
Old 06-29-2008, 08:18 PM
Depends on the interfearance fit how easy it goes on as I have seen alot of guys beat them on as they did go on hard. They all don't have the same fit!!
Old 06-29-2008, 08:26 PM
31 five window
I know all are different but in general you don't have to beat them on.
Old 06-29-2008, 09:14 PM
its easier to do with a large deep socket to get even pressure around gear then give it the ol adjusting tool.
Old 06-29-2008, 11:37 PM
sbchevfreak's Avatar
Licenced Automotive Technician
I do the same as CNC, but I use a hot plate with a mesh screen on it to get more even heat. A few minutes on this, flip once, and the same on that side, and it will slide on without effort.
Old 06-30-2008, 02:43 AM
v8hed's Avatar
AK427
Thanks guys... I'll use the gear puller to get the old gear off and I'll try tapping the new gear on. If that doesn't work, I'll heat with a blowtorch and install with oven mitt
Old 07-01-2008, 08:38 PM
540z's Avatar
Brute force and ignorance.....
Do you have a harmonic balancer (thrust bearing type) installation tool? The type that threads into the bolt threads in the crankshaft? If so, cut yourself a piece of 1 1/4" ID pipe about 2 1/2" long to work as a spacer. Use the pipe in conjunction with the balancer tool.
1. Just warm up the crank gear in the oven (about 300 degrees for about 20 minutes).
2. Grab it with your gloved hand, line it up with the keyway and slide the gear, chamfered side first, onto the pre-oiled crankshaft nose.
3. Place the pipe between the thrust washer of the balancer tool and the gear, quickly thread the balancer tool into the crank nose, and turn the nut against the thrust washer, which pushes on the pipe and in turn pushes the pipe against the crank gear.
I hope this helps,
TR
Old 07-02-2008, 06:20 AM
engineczar's Avatar
I hope this helps,
TR
This is almost exactly the method I use except I don't heat anything. What I use is a piece of square tubing that has an inside dimension just larger than the snout diameter (1.25) and long enough to ensure the gear is seated. The ends of the tubing are milled square. I then press it on with my balancer installer. By using square tubing I find that there's clearance for the key and it still contacts the gear and my installation tool.
BSE Racing Engines
Old 07-02-2008, 06:38 AM
How does that work on a 283 or 327 crank that has no threads for the installer?
v8hed's Avatar
AK427
Has anyone got a pic of this set-up, just so I'm clear? Is there any danger of stripping the crank snout threads by doing this?
Thanks.
Old 07-02-2008, 08:30 AM
Dunno about all that hammerin' and tappin' stuff. Contrary to popular belief, there is a tool made just for the task you describe. Of course, like CNC said about fitment and no thread snouts. Looks like this...
Oil out the crank snout on SBC... XNTRCI-T Engine 3 03-14-2007 12:54 PM
SBC Vibration damper install question dirtydave Engine 6 07-24-2004 09:30 AM
SBC timing chain cover Install Iroc'o Engine 17 06-17-2004 02:47 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
piston to crank install Nos Hotrodders' Lounge 8 09-18-2003 02:14 PM
