Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tool to install crank sprocket on a SBC?
Old 07-02-2008, 06:38 AM
v8hed's Avatar
v8hed v8hed is offline
AK427
Originally Posted by engineczar
This is almost exactly the method I use except I don't heat anything. What I use is a piece of square tubing that has an inside dimension just larger than the snout diameter (1.25) and long enough to ensure the gear is seated. The ends of the tubing are milled square. I then press it on with my balancer installer. By using square tubing I find that there's clearance for the key and it still contacts the gear and my installation tool.
Has anyone got a pic of this set-up, just so I'm clear? Is there any danger of stripping the crank snout threads by doing this?
Thanks.
