Tools for welding test
Well, I was doing a search on required tools for a welding test and found hotrodders.com, so here I am. So the deal is with economy as bad as it is I need to be creative. On a recent job search in my area I found a welding opportunity. The problem being I haven't worked in the trade for a long time, once upon a time I was certified for welding pipe in all positions and was quite skilled at weld AL with MiG. The jobs for flux-core and requires a test, if I can get the test scheduled what tools do I need to bring?
Thx, Ray |
tools
Thanks for the responses, I understand I need the basics as far as hand tools go, but what about power tools like a grinder/ buffer, I still have a 4 1/2" angle grinder. Are the test pieces normally ground flat? Does the backing strip need to be cut off and ground and the cap welds also?
Ray |
another weld site.
also check out welding tips and tricks. .....Jody has ifor on testing.
What test/certification are you going for? Flux core doesn't really tell us much.
If it is just for work then they may have most of the tools there except for a welding shield (autoshade if allowed)/gloves/etc. I would bring the basics with you like chipping hammer/wire brush, grinder with grinding and cutoff wheels if you are allowed. I would also bring a small hammer and a stamp kit \(just stamp you intials or ticket symbol) just to make sure it was your pieces going through the bender/xray if they will allow you. |
Well the test is described as a company test(in house).Flux core, 2G,3G,4G for structural welding. My assumption that it is a job for welding plate.
Ray |
Is this test going to be bent or xrayed? Did the company give you a
procedure to follow? What kind of flux core are you going to be welding with? I would assume it would be a cold test as well, a cold test is the welding machine w/ or w/o a wire feed will be set to zero. I would suggest to go in a few minutes early and get a feel of the machine since you haven't welded in a while, if they allow you. I would advise you to check all your grounds, whips, settings inside the machine, if you are using dual-shield (gas and flux) I would double check the bottle and regulator also. |
| Expensive Tools Vs. Cheap Tools | car2shirt | Garage - Tools | 32 | 09-22-2010 06:03 PM |
| welding test question | dreaux | Garage - Tools | 24 | 03-22-2009 10:15 PM |
| Butt welding vs Spot welding | 69ChevelleAddict | Body - Exterior | 19 | 05-04-2008 01:47 AM |
| CBD test (car buying disease test) | pigjamelectric | Hotrodders' Lounge | 8 | 02-11-2007 05:05 PM |
| tools | James Kroener | Garage - Tools | 2 | 09-21-2005 07:40 AM |
