Tooth Pattern - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-25-2007, 03:46 PM
Hey gang,
Ok I think I finally got it. I'm running a .025" worth of shims, and the backlash is running between .008-.009". Also I still have the same .011" of bearing pre-load for the differential. I got some phot's of the drive side, will post the coast side one in a bit.
These were taken a couple of minutes ago. I can now see the difference from these and the originals!
  #17 (permalink)
Old 11-25-2007, 07:53 PM
Looks like you got it!
  #18 (permalink)
Old 11-26-2007, 03:32 PM
Looks pretty good to me too. I say run it and see what happens.
  #19 (permalink)
Old 11-26-2007, 05:02 PM
blacklabzeke's Avatar
I say it's a go. Looks good.
Chevy engine doesn't fit Chevy Trans! 2000jack Engine 21 01-31-2008 10:51 AM
Ring & Pinion Tooth Contact Pattern GM 10-Bolt leejoy Transmission - Rearend 52 12-15-2006 06:26 PM
Transfer case - NP 203 - 205 jrm123180 Transmission - Rearend 2 03-24-2006 07:36 AM
Ford 9 inch to Chevy 4.75 pattern questions 3100 Special Transmission - Rearend 14 01-21-2006 07:29 AM
Metalshaping/Body Panel Fabrication Randy Ferguson Body - Exterior 15 06-06-2005 11:01 PM
