top chop revisited - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2005, 07:59 AM
top chop revisited
okay, before you all start yelling at me, I did search and look through a ton of threads on this. It's not so much a question on the top chop itself but rather the interior trim. I'm doing a 48 Chevy p/u and will be doing a 2 - 21/2 inch chop. The part that I couldn't find too much info on is what to do with all the interior trim. Is this stuff hard to weld back together since it is so thin? And to those of you who have done this...can I just get new door glass cut and use all of the old mechanicals? Thanks
barry
Old 07-07-2005, 11:18 AM
I have chopped a couple of those trucks, the window frames are thin metal but no problem welding. Other than the corner windows on the back of a five window deluxe cab are flat safety plate, all can be made by any quality glass shop.
If you have a three window cab, I have to tell you, if you drill out the spot welds on the inner cab sheet metal and remove it, it makes for a much nicer chop. After you have welded the top all back, cut the inner panel down and weld it in. That way you can hammer weld all the welds.
Old 07-07-2005, 11:25 AM
martinsr...thanks for the reply. I've been going back and forth on whether or not to chop. I love the look but this would be my first chop...just a little nervous about it. Mine is a three window and I will probably do the post lean method of chopping as i'm not going real radical on it. Another question I have is on the spot welds for the inner cab cover. How many are there? I will have to take it off regardless as I have some dents along the top back of the cab. The door window trim was bothering me as to how to weld it back. I will have to turn the heat down a lot? Thanks again.
Barry
Old 07-07-2005, 01:09 PM
Don Meyer's Avatar
If this is your first chop I'd not try to lean the post back.Window installation can be a nightmare if the post lean back is not done right. Keep everything in the same plane as stock & add metal to the roof.
Don
Old 07-07-2005, 01:55 PM
Barry, it was my first chop, at 16 years old! There are a zillion spot welds, it isn't easy removing it. But it is, in my opinion nessisary to do a nice job. the dents are NOT a reason to remove it, there are other methods.
Don is right, leaning the posts back does NOT make the chop easier. It only takes the time spent on splitting the top and puts it in another place. It isn't that hard being the glass is all flat, as opposed to curved glass, but it is still a steep learning curve either way.
At only a couple of inch chop I do believe that leaning the posts would be the way to go. A four inch chop only requires about a one and a half inch lengthen. So with two and a half that means about an inch or so, that isn't much to massage the posts.
The one that I am in the middle of right now is going four, but will be lengthed AND I am leaning the posts as well. I think it gives a much better look with the posts leaned, as long as they are not too much. A four inch chop with leaned posts looks bad in my opinion.
Old 07-07-2005, 06:32 PM
Don Meyer's Avatar
Here is a picture of my 48 so you wil see what one looks like chopped 3 1/2" lengthened 3".
Don
Name:	buford may11 001.jpg
Old 07-07-2005, 07:43 PM
Thirty years ago! Don, I was wrong, it wasn't 1 1/2" it was 2 1/2". I just went out and measured it. That was with a four inch chop. How could yours be a 3" with only a 3 1/2" chop? We aren't measuring the same thing or something. I measured the actual distance from the top had to be lengthened to line up the posts.
By the way, on my current chop (it is about half done) I am only going to lengthen it half that at 1 1/4" and lean the posts back. Unlike the way I did it 30 years ago with the full 2 1/2 Lengthen. I just think it will look better. The way I see it, when you don't lengthen the top with a 4" or so chop the windshield is laid back too far in my opinion. Because of this the glass doesn't get shortened nearly the same as if you lengthened the top, it is laid back after all. However, draw an imaginary line up vertically from the bottom of the front of the glass, and one up from the top of the glass. Now, if you were to measure between these lines it is actually SHORTER between these two lines than stock! Soooooooo, it gives the illusion that the windshield has been leaned FORWARD!.
If you lean the posts back, and draw these imaginary lines they are going to be the same as when it was stock, however, with the top lowered it looks like it has been increased because of the ratio between the distance and the height of the top. WHEW, I may have lost myself on that one.
Anyway, I plan on both lengthening AND leaning the posts to keep that ratio or something similar for a more pleasing look.
Old 07-07-2005, 08:06 PM
Hey Don, wild bed, that's pretty cool. Do you have any other photos
Old 07-08-2005, 06:22 AM
Don Meyer's Avatar
The interior trim refit is the easiest part of the chop, The area on each side of the window is removed & once the chop is done simply cut & fit & tack weld it back in place.. One tip....when the top is extended for the chop take it off again & turn it upside down. Using a thin door wood skin(home depot) & fiberglass make a headliner that you can glue material to. It can then be attached to the interior for a seam free headliner. I also att. insulation to the roof.
Good luck ,,,,,Don
Old 07-08-2005, 08:06 AM
Don, good head liner tip. There is a guy named Cole Foster out of Salinas Ca that has one of the most tasteful AD Chevys ever. He did something similar with the head liner. He took another roof and made a metal one! From below the rear window up and over to the windshield is a perfect seamless metal. He painted it a white pearl along with the dash (53 Olds as I remember) and the window frames (also 53ish Olds) for a really striking look. Look for a thread I am going to start on Coles style.
So, how about some pictures of your bed? I can't remember if you have ever posted photos of it. I just went back to the photo and it looks like you are going to bolt some "fleetside" panels over them?
Old 07-08-2005, 01:32 PM
Don Meyer's Avatar
The bed is the result of many hours of massaging metal. It was more difficult than the top chop.
I'm getting up in age, have health problems & wanted to do one last rod that will be different.
I picked the ugly duckling AD because of its round lines. I made the lines look even more round by rounding off the top during the chop.(slanting the post back would not look right on this one... It adds a razor sharp look). The doors are pulled in at the top to add to the roundness.
The bed was shaped to the contour of the cab so when viewed from the rear the cab & bed flow as one. The bed is a late model bed that I reworked making it a little narrower than the original. I then added fins that are at a 30 degree angle at the rear & 45 degree at the front. 5" were removed from NOS fenders & welded to the bed.
Good luck w/your new AD. Post some pictues when appropriate......Don
I can't seem to upload a new picture . I'll try again on the next post
Old 07-08-2005, 01:42 PM
Don Meyer's Avatar
bed picture
picture of bed...I hope
Don
Old 07-08-2005, 01:49 PM
Don Meyer's Avatar
Here is another picture. These pictures are 6 mos old. I have reworked the bed since then. The bed is now ready for paint. Next week once the hurrican has passed & the bed is painted I'll post a picture......Don
Old 07-09-2005, 07:32 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
I recently saw a chopped Gremlin. Pretty wild looking. Hg
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 07-21-2005, 10:48 PM
Roadsire's Avatar
Last journal entry: Dash mods
54 chevy 5 window top chop
Im in the middle of a 3" chop on a 54 5 window chevy truck
As this truck has the curved windsheild I had to cut the roof into
5 section and piece it back together, I also chose to cut 2.5" out below the rear window and a 1/2" in the center of the rear window so as to keep the rear window as large as possible as I do prefer this look to the "mailslot" look. If you have a 5 Window truck you can purchase laminated glass corner windows from Bobs classic glass and cut them down as the original corner windows were tempered and can not be cut as far as Im aware.
Check out my journal as I will add some pictures. This is my first chop and I must admit it is a bit unnerving to cut up a beloved vehicle until you start to get it back together, then you can sleep at night once again...... Good luck
cut, weld grind, repeat...........
TOP CHOP Bill Corum Body - Exterior 3 08-10-2008 10:29 AM
chop top of 49 merc dave perret Body - Exterior 4 12-22-2004 08:46 AM
chop the top on my 65Polara Kustom Kid Body - Exterior 1 12-12-2004 12:39 AM
1953 Chevy Chop top? Harvi53 Body - Exterior 5 06-11-2003 07:08 PM
