top dead center tool? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-17-2012, 03:36 PM
bentwings's Avatar
bentwings
I guess some us just have harder heads than others. Some have more money than common sense and some of us just like the do things the hard way. haha
  #17 (permalink)
Old 06-18-2012, 06:50 PM
Irelands child's Avatar
If you have a spark plug, it's even easier then drilling and tapping. Break out the plug insulator, find a dowel that's close in size - even a wood pencil will work. Run the piston up close to what you think is TDC (insurance so if you have an awww s@#t and lose your grip on it)put the dowell/pencil in and turn the engine via the crank bolt or whatever you use. A piece of masking tape marked/"gradulated" with a few lines will give you an idea of when TDC is reached.
Yes, that method does work and my big expenditure was a new $2 Wally World Autolite plug since I had tossed all my used ones. It sure ain't rocket science
  #18 (permalink)
Old 07-29-2012, 06:31 PM
the purdy TDC cover
I'm gonna get one of the cover's, it's be a gift from me to my motor !
there's 3 diff ones, I just gotta make sure I got the one marked for my motor plus they look really great like a Fluiddampner balancer
  #19 (permalink)
Old 07-29-2012, 10:03 PM
I'm gonna get one of the cover's, it'll
  #20 (permalink)
Old 07-30-2012, 08:14 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sometimes guys get in trouble because the damper doesn't match the timing tab. Here is a short page describing the differences in the three types most commonly seen and how to go about remarking the damper if need be. Cost is zero, but it won't trick anyone into believing you have a Fluidampr...
It's worth mentioning that using a cover still doesn't guarantee the timing marks are accurate- even if the parts all match. Manufacturing difference and tolerance creep can still make the marks off, so the best bet is to go ahead and do the drill to determine true TDC. DV gave a link earlier for determining TDC, here it is again.
The bolt holes in the cover can be carefully elongated in order to index it correctly if you find it's off.
  #21 (permalink)
Old 07-30-2012, 09:10 PM
bentwings's Avatar
bentwings
I have a cover on my motor. I drilled and tapped the snout hub (no balancer on blower motors) for a couple of 4-40 flat head screws from the hobby shop. The screws are located so the cover only goes on one way. I can remove it and replace it without losing location.
  #22 (permalink)
Old 08-18-2012, 12:18 AM
graydog's Avatar
Originally Posted by poncho62 View Post
That is basically a piston stop......A simple one can be made with an old spark plug .........
I recently made one for my Gravely 1 cyl engine. It cost nothing but a little time and the rod is adjustable.
Name:	a TDC tool.jpg
Top Dead Center KeithB123 Engine 3 01-31-2005 10:38 PM
Top Dead Center oldsmo Engine 1 07-26-2004 01:52 PM
Top Dead Center mark4 Hotrodding Basics 13 07-24-2004 12:20 PM
Top Dead Center pintoperformance Engine 5 10-17-2003 08:32 PM
top dead center ? inkfixer73 Engine 7 09-10-2003 07:59 PM
