Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Top end not getting oil up from lifters
Old 01-13-2013, 11:37 AM
Mr. P-Body Mr. P-Body is offline
Is it a "small base circle" cam?
The oil band on lifters tends to be too "low" when a small circle cam is used. The "fix" is to use Pontiac/Olds lifters (Comp #859-16). The oil band is a little more than 1/8" higher.
FWIW
Jim
