Top fill in for 29 Model A sedan - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2002, 04:52 AM
Red face Top fill in for 29 Model A sedan
I would like to fill in the top of my 29- 2 door sedan. I would like an idea as to what others have used to fill it in with. Is there a simple way or van top that would fit? What model and what year should I be looking for?
Old 10-22-2002, 06:00 PM
BOBCRMAN@aol.com's Avatar
Post
i have used caravan roof, also have used gm. m-van roof, it had a spot that worked perfect for a tinted insert.
Old 10-22-2002, 07:53 PM
Post
I have a 1930 model A 2 door coupe and when I replaced my top I took measurements and made a cardboard template of the curvature. I took that information and went to the junk yard where I found an old station wagon that had a good top with the ribs. I cut it out, took it home, did some hammer and dolly work around the edges, spot welded it skipping around to avoid warpage, ground it off, applied filler, block sanded, primed and painted and it looked like that top was installed at the factory. Wow, that was a lot of work. Hope that gives you some ideas.
