Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Top things to do when buying a used motor to drop in.
  #17 (permalink)
Old 10-30-2012, 03:56 PM
0trbo4myCHEVUICK 0trbo4myCHEVUICK is offline
It would be awsome to use a mechanical fuel pump but i know the provision may not be there as well as the cam lobe missing. If i was to keep the injectors it might be cheaper to buy the fuel tank out of the suburban as well. If i go carb then a 50$ holley in line pump will work i thought. ?
