Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Top things to do when buying a used motor to drop in.
  #29 (permalink)
Old 11-06-2012, 03:56 PM
0trbo4myCHEVUICK 0trbo4myCHEVUICK is offline
Originally Posted by 75gmck25 View Post
Just a thought (and maybe a dumb idea full of holes).
If the Vortec 350 is running, I assume it has a good fuel injection system and computer. Have you considered putting the complete fuel injected Vortec in your truck? It may be simpler than going through all the changes you need to get a Vortec working with a carburetor. And it will probably run as reliably as a stock engine.
You will need to figure out a fuel pump that works, and you will need a VSS and O2 sensors to feed the computer. The rest of the sensors should be on the engine. I'm also not sure how the computer would work with a non-computer transmission, but there should be a solution.
Bruce
Im really just a very simple (and cheap) guy. I've always owned carbed chevy's. At 22 years old maybe I SHOULD be looking for the next best "super chip".. nah..
If it was going to be cheaper to go the injected route i would but most the engines i see dont come with the comp and I would need pretty pricey fuel pump and maybe different tank. Looks like it would be about the same price and work either way. I would def gain MPg with injecters but i can work on a carb.
