Topcoat over epoxy?
Is it ok to put basecoat over epoxy or do you need to
put down a sealer or 2K first? |
Welcome, You need to put your question in the body/exterior forum and you should get an answer.
moving there......
Ontario Rodders |
Topcoat over epoxy?
I talked to a epoxy manufacturer about this.
They said its fine to put base over epoxy, but it is a good idea if the epoxy has set up for days or weeks to dry sand the epoxy with 400 0r 600 grit sand paper first, prior to laying your paint. The sanding will give the surface a tooth that the paint can work into. Thanks... X |
| Marine Epoxy Primer? | rlackey | Body - Exterior | 10 | 03-24-2005 04:14 AM |
| Barry, epoxy adhesion testing? | baddbob | Body - Exterior | 21 | 03-20-2005 09:12 PM |
| applying epoxy - gun question | Dubz | Body - Exterior | 3 | 09-15-2004 07:02 PM |
| Urethane and Epoxy Primers | bmech211 | Body - Exterior | 1 | 04-17-2004 05:04 AM |
| when to topcoat after epoxy primer? | brauler73 | Body - Exterior | 0 | 09-01-2003 11:48 PM |
