Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tops out at 5200 RPM's
Old 02-10-2013, 06:37 AM
hcompton hcompton is offline
Old & Furious
Originally Posted by 75gmck25 View Post
Also verify the travel on the accelerator cable. I had trouble with my engine flattening out at about 4K RPM and found that I had not adjusted the accelerator cable when I replaced the carburetor. I was not pulling open the secondaries and that is why power went flat.
Bruce
Good point this happend with one of my porsches. I purchased it from a guy said the motor was bad but the throttle just never opened more than a 1/4 of the way.
Fuel flow can also be effecting the high rpm range if the pump is weak.
