Toque converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2005, 08:46 PM
Malibu406's Avatar
New Member
Toque converter
I've been running a B&M Holeshot 3000 for a few years in my TH350. If a converter starts going bad, what symptoms does it show ?
Thanks
Old 07-10-2005, 04:28 AM
generally in my experiance they start to ballon out and quit working or the impellers fall off and they quit working.
you could possibly be ready for a rebuild on your trans and need the torque converter flushed.
if the converter were stripped or losing a blade it would hammer vibrate and not work. hope this helps or gives you an idea to persue.
Old 07-10-2005, 11:57 AM
Malibu406's Avatar
New Member
Thanks for the help, its doing fine right now, I've just wondered what starts to happen when it does go bad. I like to stay ahead of things
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 01:42 PM
TPS sensor and Converter question. Parisienne66 Engine 5 05-12-2005 11:50 PM
TH350 gap between converter and flexplate QUESTION chrisgarrison Transmission - Rearend 6 12-27-2004 12:32 AM
Converter ballooned ?!?!?! Slant3 Transmission - Rearend 2 06-13-2004 09:20 PM
possible bad toque converter? Deadtemple Transmission - Rearend 9 10-11-2003 07:53 PM
