toque converters - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2006, 07:22 AM
docs57's Avatar
toque converters
I have picked the manifold, cam , lifters ect. they say I need a 2200to 2500 toque converter. ? why? I do not know any thing about transmissions, help. thanks for your help Doc
Old 06-30-2006, 07:55 AM
Frisco's Avatar
Glad To Be Here
Who are "THEY"?
Proper selection of a torque converter is determined by the horsepower, torque, cam specs, vehicle weight, rear gearing, tire diameter, type of driving (street, drags, towing, etc.). Check out the Coan and/or Hughes sites and submit info to them for suggested torque converter for your application.
Coan
Hughes
Old 07-02-2006, 09:08 AM
docs57's Avatar
torgue converters
They , was comp cams, I guess I should have ask them, thanks for your reply. Doc.
Old 07-02-2006, 11:00 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
K.I.S.S.
A 2500 stall will allow the engine to rev to 2500 under full throttle until the vehicle gets moving. This allows the engine to get more into its power range. determined by its cam. A cam that makes little torque below 2500 will be pretty doggie with a stock 1600 stall converter since the car must get moving 15 mph before the engine begins to pull well.
Also a converter will "slip" and allow extra rpm if driven at a steady cruise rpm less than the rated stall speed. This is one reason that back in the 80s "lockup" torque converters were invented, to get zero slip in high gear. My factory car dropped 10% gas mileage when the lock-up switch failed.
Old 07-02-2006, 08:59 PM
xntrik's Avatar
about converters and stall speed
http://carcraft.com/techarticles/80098/
Anyone used the Dynomax Super Converters? 78novaman Engine 0 02-16-2006 06:58 PM
catalytic converters? voodoosurfer Hotrodding Basics 13 01-23-2006 07:23 AM
allstar torque converters vs hughes jimbobneutral Transmission - Rearend 7 05-20-2005 07:54 AM
Catalytic Converters? Mr.CrownVic Introduce Yourself 3 07-11-2004 05:27 AM
cheap e-bay converters?? anglia48 Transmission - Rearend 16 08-13-2003 04:30 PM
