Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - torgue wrench
Thread: torgue wrench
Old 07-26-2006, 05:37 PM
matt167 matt167 is offline
Wiki Edits: 31
yes but you need an open end pointer style/ dial style torque wrench ( that is calibrated ) and 2 sockets that are the same size welded togther, then put the pointer wrench in a vice and set the clicker for 50 ft/lbs or so and then crank on it, if it reads 5o ft/lbs when it clicks, it's in calibration.
