torker original intake manifold - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2008, 04:03 PM
does anybody know anything about edelbrock torker manifold and if possible could you show me some specs or a fact sheet about it i've been to edelbrocks web site and coldn't find anything on it just the performer and torker ll and does any body know how to hook up a msd ignition box 6a pn:6200
thanks
p.s. where do i find an oil fill tube for a 327 this manifold has the hole for it but don't know where to find one
Old 01-13-2008, 04:16 PM
DoubleVision's Avatar
The original Torker was a good intake in the upper RPM ranges, in the lower it didnt provide enough low end torque for daily driving, its runners were slightly larger and it was based on a X design, the intake was discountined for the reasons above plus other issues with its performance and was replaced by the Torker II. You can likely order a oil fill tube, but if you plan on using standard valve covers you won't need it, you can buy a plug to fit the hole in the intake if the plug is no longer present.
Old 01-13-2008, 04:21 PM
ok so what is so different then except that the torker ll has a funny angle thing where the carb mounts what is that all about and thanks for the info
Old 01-13-2008, 06:48 PM
torker manifold
the oil fill tube is sold by summit, any competent machine shop can fit it to your manifold. about 1/2 hour to do it. sam-missle
Old 01-13-2008, 08:48 PM
The torker II's runners are longer and more narrow providing more low end response but no matter, it still suffers the same lack as other open plane intakes, the loss of low end torque for upper rpm horsepower. So for street cars, we lean to a dual plane intake, for high rpm power a open plane.
Old 01-13-2008, 10:11 PM
spinn's Avatar
performer vs low rise single
DV- i agree except i have been toying with a edel streetmaster 318 intake. this is the smallest (punny 273/318 ports size) low rise single plane i have seen. it is a 0-5500rpm intake, and maintains great daily driver throttle response. it doesnt fall into the dismal torquer II pit. the 318 has a the 340 factory HP cam .43o/.444" lift, and cop heads. i have a 4 spd manual trans transfering power.
between them the difference i notice most is the loss of the off idle torque lurch forward that dual plane "performer" styles provide. however once i wind up 2500-4500 it is smoother with an unrestricted upper rpm feeling.
the performers "swell" from idle to 2500 in a jiffy. almost becoming a puller , more than a winder, cause its choking by 4500-5000rpm.
just my take
Old 01-13-2008, 10:12 PM
I have a streetmaster for a SB chevy, it looks almost identical to a torker II only with smaller runners. I like it.
Old 01-14-2008, 09:34 AM
GoneNova/406's Avatar
the torker works from 2500-6500 and works well on 350's from 3000-3500 rpm up.i just resently took one off my 406,for another slightly better which works as well on the bottom as it does the top.for just driving around in a 400-450 h.p. motor its great.mine had a verly large cam and was in a heavy vehicle.i saw an article by kevin mcClelland who helped design the torker ll and he said it was only made to handle about 400 h.p..edelbrock made a bunch of intakes like the streetmaster ,taranchala torker,they all look alike.i also have an old streetmaster that looks completely different.
Original Sbc Torker Intake.. Rpm Specs Wanted boneyard Buick Engine 1 03-20-2006 01:58 AM
Spacer between carb and intake manifold?... doc_rage Hotrodding Basics 2 02-06-2004 08:40 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
original Torker intake bullheimer Engine 7 02-12-2003 03:23 PM
intake manifold 69cougar Engine 2 12-29-2002 05:37 PM
