torko or aircraft fuel - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2008, 10:46 AM
inquiring_mind2's Avatar
a shade tree mechanic
I was wondering what the difference was between torko blue and aircraft fuel. From what I understand they are both 110 octane, The aircraft fuel is about $2 a gal cheaper. I didn't knowid it would be safe to run in my bbc. ANy help would be greatly appreciated
Chris
Old 03-05-2008, 11:02 AM
Last wiki edit: Quadrajet
Wiki Edits: 7
Well I don't know about the torco fuel but I can tell you that av-gas is very dry and you will almost certaintly need to run a top end lubricant with it to keep from burning your valves or rings.
What compression is the bbc? That's the main factor when selecting octane.
Old 03-05-2008, 11:04 AM
the compression is 12 1/2 to 1
Old 03-05-2008, 11:40 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
You'll have to rejet and retune the carb. Avgas is less dense than gasoline. Stoichiometric for gasoline is 14.7:1, more like 12:1 for Avgas. It also has fewer BTUs, but not by much. You would get the best performance from 114 race gas, but if you redesign the fuel system and use an upper cylinder lubricant additive, the Avgas will work fine.
Just don't get caught. Using Avgas on the street is a federal offense that can actually land you in jail, get the airport seized by the government, and you might get fined $150,000. No joke.
Don't know squat about Torko
Old 03-05-2008, 02:13 PM
Because of road tax not being paid?
With any government, it's all about taxes.
Old 03-05-2008, 02:40 PM
curtis73's Avatar
Wiki Edits: 16
No, because it contains lead
Old 03-05-2008, 04:05 PM
Bumpstick's Avatar
Hammer and a torch
Also AVgas is 100LL (blue version & most common think their are others...?) so its really more like 100 octane but about 4 times the lead of our old leaded fuel which helps with the upper end lube... Ran it for 2 full seasons in an LS7 BBC (12.25 to 1 compression) all roller motor with no issues at all...
But best formulation for performance is the 114 race gas...
Old 03-05-2008, 08:07 PM
What about if you put it in a vehicle that is supposed to use lead?
Shane
Old 03-05-2008, 11:56 PM
curtis73's Avatar
Wiki Edits: 16
No on road vehicle is allowed to use any fuel with any lead in it. Its a federal violation to do so. Lead was removed because its highly toxic and dangerous to the environment. Its illegal to use leaded fuel on the road in any way, shape, or form.
Old 03-06-2008, 04:49 AM
So you can't have a street car running on race fuel?
Old 03-06-2008, 06:18 AM
Stovebolter's Avatar
36 Chevy Low Cab
Last journal entry: C4 IRS
Its also designed to run at much higher altitudes isnt it? I used it for a while in a motor years ago....and it filled up my fuel bowls with a substance that looked much like cotton candy. It messed up my float level. I beleive it is oxygenated to make up for the higher altitudes and when used at ground level....its just not happy?
Dave
Old 03-06-2008, 07:39 AM
thx for all of the help. I will just go buy somw fuel with 114 octane thx
Old 03-06-2008, 10:19 AM
Avgas is rated by the Motor Octane Number, an aviation lean rating of how the fuel is when the engine is under a load. Pump gas is rated by the Motor Octane and the Research Octane Number average, the research number being obtained in a controlled evironment and is usually higher by 10 or so points, so avgas is probably more like 105 or even 110 since its rating is for use at altitude where the mixture is leaned out. It's very dry, if you have ever got some on your hands you will know what I mean, it leaves no oily residue so if you run it I'd add a can of Marvel Oil or mix it with pump gas. It has another advantage of being able to sit for long periods of time before going bad, it's pretty stable. You'll have increase your jet sizes to obtain the maximun benefits. Any fuel leaks will become apparent as the dye they use turns into a blue inky substance at the source of the leak. I use it in my boat, but I mix it with 92 50/50, runs great, I never touched the carb but that thing always runs a little rich anyway. It's got a lot of lead in it so don't use it on a car with a catlaytic converter. Airports won't let you put it directly in a vehicle (at least there not supposed to), so bring a gas can if you want some, and don't get caught putting it in your street car.
383 SBC, need input for performance issues roxanne68 Engine 24 08-08-2007 11:06 PM
Help - my fuel pump is leaking KENMO Engine 10 07-01-2007 12:39 PM
Fuel Filter Location leejoy Engine 7 05-04-2006 08:50 AM
Carb size to small???? brainsboy Engine 50 08-14-2005 04:04 PM
fuel cell installation 19nova72 Engine 5 11-19-2004 04:36 PM
